Case Mod - In Progress K.3nny's Parvum Aurora case
Discussion in 'Project Logs' started by k.3nny, 16 Jan 2013.
  1. k.3nny
    k.3nny Active Member
    27 Jan 2010
    Thnks :D!
  2. flix
    flix Active Member
    5 Aug 2009
    Very cool case :)
  3. gungravevn
    gungravevn New Member
    12 Oct 2012
    Sub for awesome skills and damn nice case
  4. k.3nny
    27 Jan 2010
    Thnks Grun :D!
  5. BCMods
    BCMods New Member
    20 Apr 2012
    Subbed, also getting one of these cases soon :)
  6. k.3nny
    27 Jan 2010
    Update :D
    Drain added to loop
    Ofcourse a custom front layer couldnt be forgotten :p so lets take a look :
    Test:
    Apply-ing to front panel
    Some details i wanted to see done
    Begon to make the pci-plate:
    Mounted
    Works flawless
    Random pics:
    My hose and liquid would be arriving soon :D!
  7. BCMods
    BCMods New Member
    20 Apr 2012
    Nice work :)
    Could you do me a favour and measure the distance between the top of the case and the very top edge of the motherboard PCB? I can't find it anywhere online. Need to know the biggest size rad i can use.
  8. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Looks great! :thumb: but....:
    Is it just me or do I see a nasty case of card warping?:eyebrow:
  9. BCMods
    BCMods New Member
    20 Apr 2012
    Probably needs a backplate, those waterblocks can be pretty heavy...
  10. k.3nny
    27 Jan 2010
    There was no support to hinge the card :p now as u can see in my update i made the PCI holder :p the card is rigid inplace now :D! and the copper blok is 400grams or more, (oldscool EK 4890) :D
  11. siliconfanatic
    10 Sep 2012
    Niiiiiiiiice!
  12. siliconfanatic
    10 Sep 2012
    looking at the pics i'd say youve got... let's see... i presume K3nny went with the norm 40mm rad soo EDIT:30mm from up-close... 65mm 55, or 75 65 with the approx 10mm overlap i see... correct, K3nny?
  13. k.3nny
    27 Jan 2010
    Here u got some pics,
    All i know, full size rads(thick rads) on the top and some good fans wil give you problems :)
    Hope i helped u with it :)
  14. BCMods
    BCMods New Member
    20 Apr 2012
    Cheers guys, big help :)
  15. Paslis
    Paslis Active Member
    13 Jun 2011
    Another crazy mod by Kenneth. :D Nice one mate.
  16. GLA-58
    GLA-58 Member
    1 Sep 2011
    :wallbash: Dear Kenny :wallbash:
    YOU have got to be stark raving mad ! uch prut.........
    The sheer madness to put beads on sleeved powercable is absolute GENIUS !!!!!!!!!!!
    I like it very much :thumb:
    greetings and peace of mind
    Gerrit
  17. k.3nny
    27 Jan 2010
    Glad we could help :)
    Thnks paslis :D
    Not mad, Just my thing :D
    *slight problem, i made fluid Its 100% the same as the purple acrylic, but in the hose its looking blackish :( only with a light right behind it its that color GRMBLLL^$*&@
  18. elAwesome
    elAwesome New Member
    1 Nov 2012
    I like it!
  19. k.3nny
    27 Jan 2010
    One of the last updates :(
    Creating the fluid:
    Demi water + mayhems red + Mayhems bleu Dyes
    Cat is paying attention! he will learn my "skills" one day!
    Too much blue :(
    Purwple! ( i know crappy cam :( )
    Primochill 3/8e x 5/8e
    No clamps needed, Clean!
    Creating the loop:
    Then started to fill the loop, Without lights the liquid is black-ish, but i dont mind it. (for now :p )
    Randoms:
    See u on the next one :) Hopefully a better cam!
    :rock:
  20. siliconfanatic
    10 Sep 2012
    The way you routed the tubes... the bacplate...
    Awesomeness.
    On a side note: barbs. Clamps. *has ww2 style flashbacks*
