News Kanguru announces eSATA pendrive
Discussion in 'Article Discussion' started by Guest-16, 20 Nov 2008.
  1. Guest-16
    Guest-16 Guest
  2. p3n
    p3n What's a Dremel?
    31 Jan 2002
    What happens if you connect both ends at once?
  3. Gareth Halfacree
    4 Dec 2007
    It creates a vortex in the space/time continuum, which will eventually swallow all matter and destroy the universe.
    Alternatively, it simply chooses whichever connection initialised first - which is likely to be the eSATA port.
  4. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    It explodes.
    Nice gadget but pretty expensive. Although... is it bootable? It's not, right?
  5. Gareth Halfacree
    4 Dec 2007
    Can't think why it wouldn't be - BIOS support depending, of course. Heck, my no-name 32MB USB1.1 pendrive boots just fine - and an eSATA device appears to the system as a standard SATA drive (heck, if you use the included bracket adapter it /is/ a standard SATA drive, as that connects to a normal internal SATA port on the motherboard.)
  6. taliban_raider
    taliban_raider Just some guy; you know
    28 Feb 2003
    Unlike USB eSata does not provide power right? So for use with eSata you would need the usb cable plugged in aswell I would assume.
  7. mclean007
    mclean007 Officious Bystander
    22 May 2003
    How come it can read through eSATA at 75 MB/s but only 30 MB/s through USB? I guess what I mean is, I know there are bus overheads etc., but why does USB 2.0 (which is rated at 480 Mbps = 60 MB/s) seem to limit a flash drive which is demonstrably capable of reading at 75 MB/s to just half the rated bandwidth of the USB connection?
  8. GoodBytes
    20 Jan 2007
    Actually, eSATA does have power that passes through... very little, and about nothing compared to USB, but it would seam to be enough for this pen drive. Also you must remember that without power at all, then no data can be transferred, as data is electricity.
  9. Lazarus Dark
    Lazarus Dark Minimodder
    14 Apr 2006
    It's using a proprietary esata connection that provides power, you actually must use the included bracket as it adds the power to the esata connector.
  10. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    huh well this is certainly interesting, so they are using the new eSata standard that combines both power and data unlike the current eSata standard which is just data. I wish we would make the move to that standard sooner so it would makes sooo much easier and require less cables....
  11. pendragon
    pendragon I pickle they
    14 May 2004
    sweet.. I wish this was cheaper though :)
Tags: Add Tags
