Windows Kaspersky pure slows pc down
Discussion in 'Tech Support' started by Simon bridgeford, 22 Nov 2010.
  1. Simon bridgeford
    Simon bridgeford i'm a pc
    25 Sep 2009
    hi
    my compaq presario is running very slow and kaspersky pure is using 98% of the cpu.
    my specs are:-
    Intel Pentium D 820 Dual Core Processor
    2.8GHz, 800MHz FSB, 2 x 1MB Cache
    512MB DDR RAM
    200GB Hard Disk Drive
    256MB nVIDIA GeForce 6200 SE Graphics
    Microsoft Windows XP Home Edition
    it is odd because i use kaspersky on all of my other machines and it runs flawlessly.
    Does anyone know how to fix this because when i first installed it it ran perfectly and now it isn't.
    thanks
    Simon
  2. Bartaggio
    Bartaggio Minimodder
    3 Apr 2010
    Was it scanning/updating whenever you checked? It tends to slow my pc down whenever it's doing that
  3. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Try reinstalling it (presuming its not just using resource to scan your comp) or install a better antivirus like Eset.
  4. Simon bridgeford
    25 Sep 2009
    no it is happening all of the time and the pc is running very slow
    i use eset on my gaming pc, everyting else runs kaspersky
  5. mrbungle
    20 Sep 2004
    512MB DDR RAM
    thats gonna run like dogshit with any antivirus tbh
  6. Simon bridgeford
    25 Sep 2009
    Lack of RAM shouldn't cause high CPU usage
  7. riekmaharg2
    22 Feb 2009
    Did you try reinstalling it?
  8. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    found these fixes.. looks like kaspersky goes nuts with certain dlls and still checks trusted apps
  9. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    Just use MSE. Our work pc's have pretty much the same hardware as you, with 512mb of ram. You won't even notice that MSE is there
