Windows Kazaa 2 Participation Level
Discussion in 'Software' started by sinizterguy, 13 Dec 2002.
  1. Altron
    Altron Minimodder
    12 Dec 2002
    I keep it open sometimes. But if I am going to play a game or something and don't want it taking up too much clock cycles and baud I close it.
  2. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    I always share overnite when I am sleeping ... let others benefit too :)
  3. Altron
    Altron Minimodder
    12 Dec 2002
    It's open right now. I'll leave it on while i'm at school, and at night.
    My level is 12, but no one has been uploading yet, since I turned it on. When I first got it it was on 24/7 :D
  4. DeX
    DeX Mube Codder
    22 Jul 2002
    I can't usualy use Kazaa while surfing or anything. Doesn't anyone find that it uses a huge amount of bandwidth even when not downloading anything? The first time I tried playing UT2003 online it was horrendous. I would keep jumping around everywhere and end up gong backwards and people killed me within seconds of spawning. After closing Kazaa it worked flawlessly. Doesn't anyone else find that Kazaa eats up bandwidth?
  5. sinizterguy
    25 Jul 2002
    I can keep surfing at pretty much ok speeds even when kazaa is maxed out on bandwidth
  6. Altron
    Altron Minimodder
    12 Dec 2002
    Someone DLed off of me, but still only 12.
  7. DeX
    DeX Mube Codder
    22 Jul 2002
    The problem with the Participation rating is that it goes up as fast as it goes down. This means that if you have Cable or ADSL you have to stop downloading in order to get the rating to go up, which is just wrong. Surely if files are to spread you need to download as well as upload. I think so long as you are uploading your participation level should go up, downloading shouldn't have any effect on it.
  8. War-Rasta
    War-Rasta What's a Dremel?
    22 May 2002
    i'm with u on that.
    by the way, does anybody know of a prog in the same style as kazaa were u can download full albums?
    i used to do it with audiogalaxy before it's sad death.
  9. sinizterguy
    25 Jul 2002
    How is the participation level supposed to drop then ?
    So if you got it 1000 and then stopped sharing, it would just stay there forever ?
    :eyebrow:
  10. DeX
    DeX Mube Codder
    22 Jul 2002
    Hmm good point. I think then it should take into account your up/down ratio. If the level went up four times quicker than it went down it would be fairer - for cable and adsl users anyway.
  11. sinizterguy
    25 Jul 2002
    Thats what I had in mind :)
  12. monolith
    monolith True Friend
    5 Mar 2002
    Ya, and keep all of the cable networks in any kind of populated area running like ****. Since cable companies like to overload nodes, with half the node running P2P software latency goes all to hell and throughput is subpar. Nothing they will do about it either.
  13. Altron
    Altron Minimodder
    12 Dec 2002
    For at least 4 hours last night I was getting horrible latency. DLing files at 60kbps: when I played Wolfenstein I would peridically lag out (lose control of character because of lag, having a ping of 999) and the Activity light on my modem was on full.
    I am paying for a service that's "50 times as fast as dial up* *36.6kbps" and getting 60k. I think Comcast is getting a little complaint from me
  14. DeX
    DeX Mube Codder
    22 Jul 2002
    Huh? How can 36kbps be 50x faster than dial up when dial up is faster?! :confused:
  15. Altron
    Altron Minimodder
    12 Dec 2002
    By dial up they mean 36.6k dial up
    So cable is supposed to be 1.83MBps
    Whilst i'm getting 60k!
  16. lcdman16
    lcdman16 What's a Dremel?
    19 Jul 2002
    is your connection speed 60kbs, or are you dling at 60 kbs? huge difference hehe :hehe:
