KD7-G won't start up after installing a new heatsink
Discussion in 'Hardware' started by xen0morph, 14 Aug 2004.
  1. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    Just installed a Coolermaster Aero 7+ on my Athlon XP2400 on Abit KD7-G. However when I press the power button it starts up for about half a second then shuts down. Is this an indicator that the CPU core isn't making proper contact with the H/S, or is it likely to be something else?
  2. El_JimBob
    El_JimBob Minimodder
    28 Dec 2003
    Check in the BIOS to see if there is some kind of 'cpu fan failure' prevention method enabled.
    The Aero 7 has adjustable fan speed, and at its slower speeds, most BIOSes assume the fan is about to fail (or assume that it isnt working at all) and shut the computer down as a precaution (to protect the processor from overheating).
    I had the same problem the first time i used my Zalman flower cooler with its slow spinning 92mm fan.
    This option will usually be situated on the page where you can observe voltages/temps, etc. Disable the option, save changes and then reboot - hopefully all will now be well.
    Let us know if it isn't....
    Good luck :thumb:
  3. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Board doesnt boot ;)
    could indicate a short somewhere, either that or the fan fail as suggested. To test this whack a higher cfm fan on the CPU fan header. If it boots then you need to turn off fan fail. If not then theres another issue somewhere... Check for shorts, and that the PSU is ok.
  4. El_JimBob
    28 Dec 2003
    Damn lack of sleep :p
    Yeh, like he said :D
  5. McWarren
    McWarren What's a Dremel?
    22 May 2003
    I had the same problem with an Abit NF7-S, so I guess this will apply. It was just a simple case of re-seating the CPU and heatsink.
