News Ken Levine responds to BioShock widescreen issue
Discussion in 'Article Discussion' started by CardJoe, 22 Aug 2007.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Bauul
    Bauul Sir Bongaminge
    7 Apr 2007
    I bet you it gets fixed in the first patch.
  3. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    Well that's astonishingly easy to fix anyway, isn't it? Just wind up the FoV angle. Probably a one-line code change.
    Phil
  4. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Nice to see a response, hopefully he will announce that they will not be changing anything.
  5. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    And I thought avatars were only meant to reach 85x85. For shame.
    Hopefully they'll fix the bug.
  6. K
    K 528491
    31 Oct 2001
    That's a pretty negative reaction. It contradicts what the developers originally said about widescreen too.
    A good fix would be the option to play in either FOV in widescreen, HOR+ or VERT-, it's a ridiculously simple fix either way.
  7. Jamie
    12 Mar 2001
    Don't get me wrong, I'm all for getting more FOV in the game but games don't make themselves and at some point there was a decision to extend vertically onto 4:3 and not to give widescreen more FOV than standard format.
  8. K
    K 528491
    31 Oct 2001
    Before or after they confirmed the complete opposite? ;)
  9. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    There is a slight typo in the article;
    May want remove the N on the end of ratio there.
  10. Vakuum
    Vakuum What's a Dremel?
    4 Jun 2004
    I just hope they fix the AA issues in Vista so I can enjoy this game even more :)
    Seems WinXp users are able to force AA on this game, but no luck for vista users as of yet in either dx10 or dx9.
  11. Jamie
    12 Mar 2001
    I bet the confirmation came from someone who didn't know or didn't bother to find out what the developers had or were doing.
  12. Silver Shamrock
    Silver Shamrock What's a Dremel?
    19 Sep 2005
    The confirmation came from Chris Kline, a lead programmer. This has been pointed out to you in a previous thread and even says so in the actual article itself.
  13. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    Who cares?
  14. mikeuk2004
    mikeuk2004 What you Looking at Fool!
    3 Sep 2004
    Exactly
    Everyone else, Shut up and play the dam game. :) Id be more worried if the game is a flop than the aspect ratio.
    On another note. What does FOV mean? I hate all these abbreviations.
  15. Jamie
    12 Mar 2001
    Yes because he has a good track record for being correct doesn't he.
    Field of view
  16. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    FOV - Field of view probably
  17. Hugo.B
    Hugo.B What's a Dremel?
    4 May 2007
    Joe martin is so Bioshocked(yes, I had to use that expression) that he's beginning to sound like a 2K rep.
  18. mikeuk2004
    3 Sep 2004
    ah, now I get you :) Cheers for clearing that up.
  19. ElZog
    ElZog Defeater of Satan's Transformo Sofa
    14 Jun 2007
    It's the use of securom that is annoying me, rather than this problem which has already been fixed (a member of the 2k forums has apparently made a patch for it). I hope the anti securom patches come soon (from official or otherwise sources) as I really hate software like that when I am a legitimate owner of the game (securom limits the user to 2 installs of the game, including on the same computer if the OS is changed). Also I hear the limited edition DVD and soundtrack are really crap and many of the figurines are arriving broken.
    Game should be awesome, but seriously, so many things have suddenly popped up today.
  20. DougEdey
    5 Jul 2005
    No, the issue has been responded to.
    Basically this is what happens when you use securom.
    Install Game -> Securom checks server -> Server says 0 have been installed -> Securom marks game as installed -> Servers record it as #1
    Install game -> Securom checks server -> Server says 1 have been installed -> Securom marks game as installed -> Servers record it as #2
    Install Game -> Securom checks server -> Server says 2 have been installed -> No more installs
    Uninstall Game #1 -> Securom checks server -> Server says 2 have been installed -> Securom marks game as uninstalled -> Server goes to #1
    Install on 3rd PC -> Securom checks server -> Server says 1 have been installed -> Securom marks game as installed -> Server records 2 installs
    Basically it's 2 concurrent installs, you MUST uninstall the game before reformatting or upgrading hardware
Tags: Add Tags
