Linux Kernel Update Problems? (fao: kargin?)
Discussion in 'Software' started by Ubermich, 8 Apr 2003.
  1. Ubermich
    Ubermich He did it!
    21 Jun 2002
    OK, everything went fine when I went by the old list you had up, kargin. But I went by the readme which says:
    cd linux
    make mrproper
    make xconfig
    make dep
    make bzImage
    make modules
    make modules_install
    Then it says to copy linux\arch\i386\bzImage to the location of my bootable kernel (is this my \boot directory? The readme says that if I don't use a boot disk I probably use LILO. I use neither a boot disk nor LILO :( )
    I know there was something different in the list Kargin gave before, but don't remember what.
    Thanks in advance.
  2. SerpentBlade
    SerpentBlade What's a Dremel?
    10 Apr 2003
    what do you use to load linux, loadlin? you need to configure your boot loader to use the image you created, by whatever means. If it is lilo, its quite simple to configure, just run:
    make bzlilo, and it will take care of copying your old working image to LinuxOLD, and your new one to Linux.
    But it all depends on what you use to load linux at startup
  3. Kargin
    Kargin Overdose . . .
    18 Sep 2002
    With all new kernel versions, once you've typed :
    Just type:
    make install
    Handles everything for you. All you have ot do then is open /etc/grub.conf (your still using the correct loader aren't you :p) and make sure the options are how you want them (default option, time out, etc). Then just reboot and select the new kernel and assuming you did everything correctly, you should have a new kernel. When your running xconfig, before you do anything, make sure you open the proper config file (/usr/src/linux-2.4.xx-x/config/kernel-2.4.xx-i686.config usually) or it will just save your options to RAM or Swap, both of which are useless once you reboot ;)
    Cheers mate.
    EDIT: Mayhap I'd better put that list back up . . . . I just removed it cuz I learned older kernels don't use it, although I'm not sure when they implemented it, and also it was too specific to the x86 archetecture. . . Hmmm...
    EDIT AGAIN: pay no attention to my inability to type or spell today.
  4. Ubermich
    Ubermich He did it!
    21 Jun 2002
    Woohoo! Thanks again Kargin! Now all that's left is:
    1: get sound working properly
    2: ?
    3: profit.
  5. Kargin
    18 Sep 2002
    1/ Do you still remember how to set up sound ?
    2/ ?
    What the . . . ? Err...
    3/ Sure, Anything over a tener is good :p
  6. Ubermich
    Ubermich He did it!
    21 Jun 2002
    1) I'll get her figured out, and if I don't I'll post back here. I thought I got the settings right in xconfig, but we'll see.
    2) ?
    3) We're thinking something bigger. Something to make us RICH!
    </south park underwear gnome>
  7. Ubermich
    Ubermich He did it!
    21 Jun 2002
    Is there a way to see the text that is shown on boot? There was an error with my chipset, but I can't catch exactly what it was... (this is the stuff before "Red Hat 7.3 Press l to enter manual boot" )
    Edit: nm, I found it.
  8. Kargin
    18 Sep 2002
    Out of curiosity, what was the problem ?
  9. Ubermich
    Ubermich He did it!
    21 Jun 2002
    there's still a problem. But I think the official ALi drivers will get it sorted. Going to deal with it later.
  10. Ubermich
    Ubermich He did it!
    21 Jun 2002
    Got the problem sorted... even though I accidentally did the same thing I did before :eyebrow: Oh well, I know how to do it properly for next time. Now to get to... umm. winex!
  11. Kargin
    18 Sep 2002
    *hands Uber a wooden board with a nail through it*
  12. Ubermich
    Ubermich He did it!
    21 Jun 2002
    /me lights stick on fire and proceedes to beat computer with it.
    btw, how the heck does one beat Bumpy Ride in tux racer??? I can't get under 33 sec :(
    Edit: oi. "Bash: unknown command: cvs"
    le :sigh:
  13. Kargin
    18 Sep 2002
    I only played tux once (the one time I actually got my card working) and only played some level I don't even know what it was, I lost though.
    Err.r.. Redhat can't find cvs ?
    That's bad, mm'kay. cvs is the core of all existance.
  14. Ubermich
    Ubermich He did it!
    21 Jun 2002
    That's what I'm sitting here thinking. WhatdoIdo!?WhatdoIdo!?WhatdoIdo!?
    Why is it that when I do something, it can go just fine the first three thousand times, but then when I think things are going right, it goes wrong?
    /me proceedes to beat pc more.
    Edit: got that much. Now I need to find the xlib and xfree86 devel stuff :(
    /me kicks self for not installing it in the first place.
