Electronics Kettle (IEC) pass through dilema
Discussion in 'Modding' started by Goatee, 4 May 2016.
  1. Goatee
    Goatee Multimodder
    19 Apr 2015
    Hey,
    So building a new rig, still watercooling even though its just a 13L Metis. I just tested everything to make sure the board it powers up and I have come across a slight issue. The pass-though connector that runs for the power supply does not want to fit any more. I appear to have put a radiator in the way. :)
    So does anyone have any ideas? Would ideally like to keep a connector there, thinking something like a right angle pass through but I cant seem to find anything, that would fit given the 21mm of clearance. I might just end up running a cable directly to the power supply.
  2. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I was going to suggest you just get a right angled kettle lead and connect it direct, if the kettle plug will go through the hole great, if it won't just cut the moulded 3 pin plug off and fit a new one.
    Scrub that, how are your soldering skills?
    Goatee likes this.
  3. Goatee
    Goatee Multimodder
    19 Apr 2015
    That looks almost exactly what I'm after.
    If I could find one with spade connectors then that would be perfect as I am not sure I would trust my soldering. I guess the search term I was looking for was IEC.
    I guess one of these would do the job. http://uk.rs-online.com/web/p/iec-connectors/2615856/
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    Is there space to cut a new hole for it above the existing one so that it clears the rad?
  5. Goatee
    Goatee Multimodder
    19 Apr 2015
    It would interfere with the next radiator i'm going to install above it. :)
    Went for one of these.
  6. Goatee
    Goatee Multimodder
    19 Apr 2015
    Got it fitted this weekend, like a glove.
    Also got my PSU cage / RES holder sorted :).
    Cheers for the help guys.
  7. Arboreal
    21 Jan 2011
    Very nice, that came out really well. A smart looking compact beastie in the making.
