Anyone know if you can buy a kettle lead with an inline switch? I have a fairly hefty sub for my surround sound system in my lounge and the sub doesn't have any sort of power switch so unless I unplug it (which is awkward due to it's socket location) it's constantly on. Failing that what sort of inline switch could I buy and fit that would be man enough for the job. Thanks.
I tried looking for one myself but failed! Like the PS3 switch they do for figure of 8 plugs but in kettle plug form... Unfortunately I draw a blank!
@Carl Yeh I was thinking of one of those as I have fitted them to lamps for people but the kettle leads have much thicker cable and I don't think I've come across a torpedo switch that would accomodate such a cable. I will go and have a quick google.
Alternatively, you could get a power distributor board that has individual switches. What type of sub is it? Most go into standby when not in use.
Hmmm, decided to shift the beast and have another look at the back (hasn't been moved since I installed it some 3 years back) and boy do I feel an idiot. Yes it does indeed have an on/off switch, it also has an auto function that allows it to switch itself on presumably when it senses an input. I'd still like to isolate it completely so I'm going to see if it has some info on the back about power draw.
I wouldn't trust anyone at any Maplin I've ever been to to even tell me where yyyy product is located in store, afaihe they're all incompetent. Hell I've even seen women working there! /jk TSB
Aegis Evo Just set it to auto and it didn't go into standby after about 10 mins so not sure if that's working or not.
I'd go for a remote control mains socket adaptor like this: Handy little things, a set of 3 is about £15-20 (I think I saw Maplin have a single one with remote for £10). Removes the reaching-down-for-a-switch from the equation completely.
These ^^ and then hack them with an arduino with a nic so you can turn your sub off and on from anywhere in the world so long as you have network access
auto sleep is great, until it breaks and then you are stuck with a sub that is stuck off. one of my older subs does this, and the only way to make it come back on is to spike it with a whole heap of signal, normally the only way to do that is to unplug the terminals, load them with signal, and plug them back in and hope that the spike is enough to trip the relay. dont do that unless you have that problem, else, you will probably break something. spiking audio gear isnt fun.
