Windows " key becomes a @ key?? WTF?
Discussion in 'Tech Support' started by Slizza, 8 Oct 2009.
  1. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    Ok this is happening more and more lately and it happens to a friend too.
    At random times when i try to type a " it shows up as a @ and i need to hit the @ key to get a " and vice versa.
    WTF is this?
  2. hugo60
    hugo60 New Member
    28 Aug 2009
    I think that is the american keyboard layout or something, i remember having the same problem with a certain game.
  3. yodasarmpit
    yodasarmpit No longer the other Brett.
    27 May 2002
    Yep, US keyboard layout.
    You can change in the OS settings.
  4. Krikkit
    21 Jan 2003
    Mine seems to randomly revert back to the US keyboard settings once in a while, probably due to some install troubles. Very irritating.
  5. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    It happens quite often on my main pc (Vista 64bit) usually after a Windows update.
  6. oatey4519
    oatey4519 can't be arsed...
    5 May 2009
    Not seen that happen on W7, but vista i always happened..
  7. opal
    opal Eh?
    21 Jan 2009
    You could remove the US layout.
    Control Panel > Region and Language > Keyboard and Languages > Change Keyboards
    Might be a little different for Vista as I'm using W7
  8. livesabitch
    livesabitch life is what you make it!
    8 Oct 2009
    you need to remove the US layout and install the UK layout in control panel. once done it should say "settings will be changed after restart!" give it ago and check it! should be fine after that. also have vista 64 (ultimate)
