Modding Key Lock
Discussion in 'Modding' started by Mayze, 15 Mar 2002.
  1. Mayze
    Mayze PH34R my ROBO Squirrel!
    28 Jan 2002
    i think it'd be cool to have a keylock...I dont have the key for this one, but I'd go buy a new one. where does the thing plug into though? somewhere on the mobo???
  2. LoopyJuice
    LoopyJuice Astronomical
    24 Jun 2001
    by the looks of is it plugs into the power header on the mobo where the on/off switch plugs into mobo and u take out the power switch so it doesnt work, wouldn't take a lot to start tho, just rip off the side and hook up a normal switch :rolleyes: i wouldn't use that if you want security, if u want coolness then go for it ;)
  3. linear
    linear Minimodder
    5 Oct 2001
    AT boards (remember those?) had a header for that, it would lock the keyboard and mouse as I recall, I never used mine at all.
    You could use it to interrrpt the power button, so it would require a key plus the power button to fire up your peecee...
  4. Alaric
    Alaric code assassin
    3 Nov 2001
    1st para: yup old mobos had special headers... were really b4 my time
    2nd para: I thinking of doing it to lock out power switch too... possibly reset too if i bother to think of a way to do it :rolleyes:
  5. cderalow
    cderalow bondage master!
    23 Jan 2002
    pretty sure my mb still has one... i'd have to consult that strange thing called a manual though
  6. Mayze
    28 Jan 2002
    :rofl: LOL. yea actually this is out of a realllllly old pc. which is now in pieces on my living room floor :rolleyes:
    also, theres a Connector not being used by a plug right above the PWR_LED...it says GRN_LED, whats that?
  7. brianpodskalny
    brianpodskalny ladies night!
    3 Nov 2001
    could be the led for the turbo button or summat.
  8. LoopyJuice
    24 Jun 2001
    yeah i think that is for another led :rolleyes:
  9. Mayze
    28 Jan 2002
    i kinda figured out that much on my own ;)
  10. Sgt. Gimp
    Sgt. Gimp What's a Dremel?
    11 Nov 2001
    GRN = Green = enviromently friendly = suspend mode maybe ?
    My mobo has the header for a keylock.
  11. LoopyJuice
    24 Jun 2001
    mine has a header for a smart card reader, just need to find one now :rolleyes:
