Motors key stuck in petrol cap
Discussion in 'General' started by pranks7er, 4 Jul 2007.
  1. pranks7er
    pranks7er mange tout
    25 Dec 2002
    hi whats the easiest way get a key outta the petrol cap when its not in the car if you know what i mean
  2. Nexxo
    23 Oct 2001
    Turn. Pull.
  3. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Presumably there's a release that only allows you to remove the key when the cap is inserted correctly, you have to synthesize this part of the car; post a photo and someone should be able to tell you where to manipulate it.
  4. RTT
    RTT #parp
    12 Mar 2001
    Hammer
  5. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    dremmel :naughty:
  6. dullonien
    dullonien Master of the unfinished.
    22 Dec 2005
    Put it back in the car???? Soriously though, used to have problems with my dad's 4x4 I used to drive. Used to just take alot of pulling and a bit of cursing. More information would help to identify exacly what's wrong with it, otherwise might as well just get it outta there any way possible, via RTT or Steveo's suggestions.
    Before anyone starts on the global warming thing, my dads a farmer and only uses the 4x4 when necissary.
  7. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    Penetrating fluid, and if that doesnt work, heat the lock and cool the key.
  8. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Some stay in the cap until the cap is put back in the car. ;)
    Tried that?
  9. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    This must be a europe thing, you mean there's a key in the gas cap to take the cap off the car?
    Is that to keep people from stealing gas or something?
  10. ElThomsono
    18 Mar 2005
    Yeah, and most have a cover that can't be opened from outside (there's a switch inside the car).
    I'd always assumed it was so that you couldn't fill it with the engine running, with both keys on the same ring you have to kill the ignition to open the cap.
  11. chrisb2e9
    18 Jun 2007
    cool, I dont think i've ever seen a car that needs a key over here, my car has a button/tab/thing to pull down by the drivers seat to open it.
  12. Atomic
    Atomic Gerwaff
    6 May 2002
    Yep, so you can't drive off with the filler nozzle still in the car... imagine the damage that would cause.
  13. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Yeah, most cars are like that here too, a button or lever in the cab, but some older cars still have a key lock on the outside.
  14. DougEdey
    5 Jul 2005
    You mean like this?
  15. ch424
    ch424 Design Warrior
    26 May 2004
    As already said, you're not supposed to take the key out of the cap unless it's in the car, so you'll have to use pliers and bits of metal to fool the cap into thinking it's attached properly.
  16. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    Hmmm....
    mine got stuck, and it was stuck there for a couple off weeks, till dad took some mole grips to it and pulled hard :D
    (luckily this was on my FAKE filler cap and so didnt affect me at all :D )
  17. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    Not much actually. Gas stations here are required to have self sealing disconnects. Once the hose has been pulled out it self seals and the hose gets to go for a ride. Happened once at the gas station my buddy works at. no spill, but the lady was red in the face.
  18. Atomic
    Atomic Gerwaff
    6 May 2002
    Ah I see, them safety chaps think of everything :)
  19. Spacecowboy92
    Spacecowboy92 Gettin' Lazy
    10 Apr 2006
    why do you have a fake filler cap?
  20. Stickeh
    20 Jul 2003
    On mini cooper s models back in the day, the mini was fitted with tanks on the left and the right hand side of the vehicle for extra distance, (one tank is about 32L / 7.5Gallons big / around 300 miles... )
    The person before me fit the other fake one, as it looks good, doesnt cost much and makes the car symmetrical, the rear end nice looking, and makes people ask and wonder :D
