keyboard andmouse have stopped working
Discussion in 'Hardware' started by pranks7er, 30 Jan 2005.
  1. pranks7er
    pranks7er mange tout
    25 Dec 2002
    allof sudden my keyboard and mouse stop workin i think something is rong with the ports usb and ps2 i have triedother keyboards and mouse no change! any idedas what problemcould be the computer boots and it detects the keyboard cause i dont get the no keyboard attached message.
    any help would be appreciated
  2. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    I think something has gone wrong with your ability to write proper sentences too :eyebrow:
    If no keyboards, mice, etc work in the motherboard's PS2 or USB ports, something has either gone wrong on the Bios end of things, the OS has gone insane, or the motherboard has decided to let those ports crap out. The latter of these is the most likely scenario imo.
  3. pranks7er
    25 Dec 2002
    :grr: ok so probably ports packed in??
  4. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    He doesn't have a keyboard, what do you expect? ;) :hehe:
    Is it just one USB port that died or all of them?
    I tried searching Google about this and found a few similar cases, but no solution to the problem. They may have just flat-out died. In that case, you need a new motherboard. :blah:
  5. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    Check the USB ports with other, simple USB devices (jumpdrives or such).
    Otherwise, sounds like an OS problem? Or your mobo has crapped out...
  6. pranks7er
    25 Dec 2002
    yea it is the ps2 and both usb ports, i tried usb hub it didnt work, i cant get into bios to set boot from cd so i can reinstall i should just disconnect the hds first and let auto detect take over shud i
  7. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    you can attempt a clear CMOS to make it default on the settings. Most bios have default boot order as floppy, cd, Hdd.
    But if the ports are shot then this is only going to make things worse
  8. vvsonikvv
    vvsonikvv What's a Dremel?
    2 Feb 2005
    check to see if the pins are physically bent and shorting each other out on the mouse and keyboard ports. I think its a good idea like the other guy said about clearing the CMOS...
    check all the wiring to see that there are no shorts on the mobo or anything. Unplug the power plug from your psu and try again. I dunno anythings wortha try and sometimes random stupid things work.
