Keyboard choice...
Discussion in 'Hardware' started by vaderag, 5 Aug 2007.
  1. vaderag
    vaderag I know what a Dremel is...
    19 Jul 2007
    After much deliberation, i have come to a decision on a keyboard...
    It's going to be one of the following three:
    Saitek Eclipse 2 (£30inc) - advantage: Backlit, Basic, Not Too Long. Disadvantage: uglyish, no programable media keys
    Logitech G11 is (£38inc) - advantage: All the above. Disadvantage: longer than a very long thing
    Logitech Basic Media thingy (£13inc) - advantage: media keys, cheap. Disadvantage: no backlight, nothing fancy, not 1337...
    So...
    Which would you go for?!?
  2. severedhead
    severedhead What's a Dremel?
    19 Dec 2002
    I have an original Eclipse and I love it. Just the right size, no pointless buttons I never use and I can see what I'm doing in the dark.
  3. capnPedro
    11 Apr 2007
    G11. Love the G15 to bits, but the LCD is more useless than a less than useful thing.
  4. vaderag
    19 Jul 2007
    How much do you find yourself using the macro keys?
  5. capnPedro
    11 Apr 2007
    Depends on the game. When I played WoW, I had about 24 keys that I would use once a minute. Or something crazy. Playing RTS, I use them a bit. FPS games can benefit from them a little (rapidly fire - make pistols more effective, quickly switch to nade, throw and change back to main weapon etc.) and of course you've got to devote a few keys to "<button to say to all> BOOM HEADSHOT!<enter>" and the like!
    All in all, I use them quite a bit. But it really depends on personal preference and playing style. I do use them more than I expected though.
    oh, and it's great to be able to type out in a milisecond phrases which i can never remember, such as my mobile number etc.
  6. vaderag
    19 Jul 2007
    That last use i never thought of actually...
    My biggest worry is that it's not going to fit on my desk properly! Even with my standard sized one there isnt that much room for my mouse! Is it really as long as it looks?!?!
    How about the layout of the insert/delete/home etc - are they normal?
  7. vaderag
    19 Jul 2007
    Oh dear, i've just discovered another nice looking keyboard...
    The Microsoft Reclusa - fits the same category as the logitech i guess!
    Can anybody tell me actually how long the logitech is (in cm)?!
    Thanks
    EDIT: After reading a couple of reviews, scrap the Reclusa...
  8. capnPedro
    11 Apr 2007
    G11/15 is 55cm long by 22cm (26 with wrist rest). It is huge.
  9. Krikkit
    21 Jan 2003
    I know this isn't quite what you're after, but I love my MS Internet Keyboard - it's got 8 programmable buttons on the top (nothing too fancy), and for most games you can just bind whatever taunt you want to a normal unused key with a bit of effort. It doesn't take much room up either, which is nice. :)
  10. vaderag
    19 Jul 2007
    Wow - that IS huge...
    What I dont understand is that the reclusa is the same size:
    http://img5.pcpop.com/ArticleImages/500x375/0/474/000474897.jpg
    but it seems to have less keys!? And neither appear to be sacrificing key size or anything...
  11. AFX
    AFX "Bling" Silver Mountain 2
    19 Sep 2006
    go with the elchepo!
  12. vaderag
    19 Jul 2007
    I very nearly just bought a G11 from Scan's today only...
    Managed to stop myself tho - i'm too worried about the length...
    I've really pursuaded myself that i need a backlight now :sigh:
    Wish there was a guide on modding your keyboard to add backlighting!!
  13. Krikkit
    21 Jan 2003
    Why the hell do you need a backlight? I'm sure it's more want than need. :p
  14. vaderag
    19 Jul 2007
    Well, it probably is way more want than need, however the number of times i've found myself struggling to find a key in the dark, i think it'd be dead useful!
  15. Zurechial
    Zurechial Elitist
    21 Mar 2007
    I use a Saitek 'Gaming Keyboard', which is essentially the same as an Eclipse, but has a silver body, black keys and blue backlighting, and comes with a programmable command pad.
    Personally, I find programmable keys useless, but look this keyboard up if you want those features.:thumb:
  16. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
  17. vaderag
    19 Jul 2007
    nice.
    But WAY out of my price range!
  18. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    Drill some holes into back of keyboard, put LEDs under some keys + wire to port = cheap backlighting :p
  19. tzang
    tzang Traditional Nutter
    7 Jun 2007
    The Microsoft Reclusa is a pretty good keyboard contrary to what some reviews say. I'm biased because I spent a ridiculous amount on getting it along with the Habu mouse.
    Build quality is good, blue backlight isn't harsh in the dark and keys are fully customisable (some fixes with the latest software, version 1.02). You also get two USB ports, which is rather handy. Some reviews I saw before buying the keyboard has mentioned that if the keyboard is raised, there is virtually no grip on the keyboard... one must question what material they were testing the keyboard on as I've tested mine on laminated wood, glass and metal surfaces and there is plentiful grip. You also get a comfy keyboard rest and your typical Microsoft silent key press.
    That said, we come to the bad points. The two knobs included (I'm the third knob... for buying it :p) are rather useless. The volume knob is fine but offers no mute function. Whenever you want to use the numpad, you will find it gets rather easy to press the CD eject button by accident when hitting the Enter key and the backlight cannot be turned off. The transparent plastic bit at the top with Microsoft written on and fancy glowing LEDs for num/caps/scroll lock is a dust magnet. Other than that, the keyboard is just another keyboard with a premium price, you pay £30 more over a standard keyboard to have two knobs, 10 extra keys and backlight, or whatever features the other keyboards include.
    You need to justify the costs. For £5.86, you could get this, which is a very good Microsoft keyboard. Good build quality and media keys. In fact, it's a great keyboard considering the price.
    [EDIT] The keyboard I listed above only comes in PS/2 though :(
  20. Krikkit
    21 Jan 2003
    The one above is basically what I have now - it's the newest version in fact, and it rocks.
    I don't need a backlight, because it's lame. I don't need millions of keys, I just want to start Winamp, WMP, Thunderbird, Firefox and Azureus without using the start menu. The keys are nice, it's well built, and if I break it, it doesn't cost the earth. Oh, and it's PS2, which means the lameness of USB keyboards doesn't worry me. :)
