Modding Keyboard LED modding
Discussion in 'Modding' started by Boss_Playa, 7 Jan 2002.
  1. Boss_Playa
    Boss_Playa What's a Dremel?
    6 Jan 2002
    How do you guys mod your keyboard with blue LEDs. I am only getting 1.9v to power the LEDs so im stuck with green, orange and red:(
    Any ideas?
  2. linear
    linear Minimodder
    5 Oct 2001
    Trust the force, and just stick in a blue LED. (If you are still skeptical, try it with your scroll lock first.) The voltage dropped across a working lit LED isn't necessarily fixed by the supply (the supply may be more like a current supply than a voltage supply).
  3. LaPPe
    LaPPe What's a Dremel?
    3 Nov 2001
    Hey at least you can have LEDs. I was very eager to get my Logitech Cordless Optical (the schweeet black thing) and have it fittet with blue LEDs - BUT NO - the things does not even have any LEDs :(
  4. Warbear_nG
    Warbear_nG What's a Dremel?
    27 Dec 2001
    so why is that stopping you?
  5. japala
    japala What's a Dremel?
    8 Dec 2001
  6. Cheese
    Cheese Doc
    6 Oct 2001
  7. bHawk
    bHawk What's a Dremel?
    5 Jan 2002
    I dont know much about EL wire, but would it be possible to put electroluminescent wire in the keyboard using power from the keyboard instead having an external power source like in the above example?
    Most EL keyboard mod kits have an external power source, whice means they have cables coming out of the keyboard, but IMHO it doesnt look very good.
  8. Cheese
    Cheese Doc
    6 Oct 2001
    Yeah if you're using a USB keyboard you can feed off the 5V line - 5V inverters are hard to find though :(
    Cheers,
    r.
