Modding Keyboard mod
Discussion in 'Modding' started by Spoonhead, 17 Jan 2007.
  1. Spoonhead
    Spoonhead What's a Dremel?
    26 Jul 2005
    Hey guys. I am just woundering if anyone knew the best way to cut out the letters on the keys. I want to then stick red leds in each key to back lit the letters.
    Any ideas?
  2. LuitvD
    LuitvD What's a Dremel?
    13 Aug 2006
    your keys will have to be hollow to be able to do that anyways... if that's what your keys are, use a dremel + a steady hand ;)
  3. bumfluff
    bumfluff What's a Dremel?
    18 Aug 2006
    I would use a very very thin drtill bit or something as cutting it would be very difficult. Plus I don't think this is a very good idea of a mod as there are a lot of keys on a keyboard and you will just blind yourself with that amount of LEDs. Also wiring them up will be a big pain.
  4. LuitvD
    13 Aug 2006
    plus, your keyboard will get really filthy during use, as there are holes in your keyboard which aren't that easy to clean...
  5. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    you would have to laser cut or waterjet them to get it to work and not look like ass. i dont care how steady your hands are, there are a lot of keys on a keyboard and a lot of chances to screw up as tedious a job as this is.
  6. MixWizard
    MixWizard What's a Dremel?
    16 Jan 2007
    you would have to get them laser etched as compaq said. otherwise youll get the holes filled with dirt and itll be horrible to type with
    check out
    http://tinyurl.com/2tw782
  7. the fodder
    the fodder What's a Dremel?
    26 Jun 2006
    just buy yourself a Decky They only sell custom keycaps in packs of 12 or you could just get the caps.
  8. frogle79
    frogle79 What's a Dremel?
    28 Nov 2006
  9. Stwongbad
    Stwongbad What's a Dremel?
    8 Jun 2006
    holy crap those decks are look AWESOME.
    if they werent so f'in expensive jesus christ!!!
  10. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    Ive got to say. I got a saitek eclipse II keyboard and I absolutely love it. it so far has been the best keyboard I have ever owned. It types really well if that matters to any of you. It also has 3 selectable backlight colors (blue/red/pink) where pink is a combination of both blue and red so it lights the keys up a little bit better with more light.
    The problem with the keyboards that light up the keys so much is that it gets really distracting at night trying to type with it. That is to say you should already know where all the keys are on your keyboard. but its nice to see what you are doing. Really I have no gripe about the saitek at all. great keyboard that I would not hesitate to buy again </fanboy>
  11. ikra
    ikra What's a Dremel?
    2 Oct 2006
    the backlights are the selling point of the eclipse 2, and the good thing about it is that it has simplistic design.
  12. sparkyftw
    sparkyftw What's a Dremel?
    10 Nov 2006
    I will agree, I love my saitek eclipse II also. Best christmas gift this year by far.
  13. MixWizard
    16 Jan 2007
    they are great keyboards have been using one since it was released. The only compaint i can come up with, having used the Eclipse 1 is that the backlights arent as bright. But it is a very good keyboard all the same. and as warrior said you should know where the keys are so it doesnt matter :p
  14. Vequalsir
    Vequalsir What's a Dremel?
    25 Jun 2004
    Saitek Keyboards
    I really like the EclipseII Boards. I found mine for $65 and love it.
  15. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Ive got the saitek pc games keyboard and have been put of saiteks range. I have never managed to get the additional keys to work on eather linux or winbloze
  16. Lunn1
    Lunn1 What's a Dremel?
    23 Jan 2007
    those keyboards arent really that much, i bought the G15 by Logitech for 100 USD, which is roughly 51 (your currency). its truthfully a nice keyboard, backlight that can be adjusted to 3 different brightness, 15 progammable keys or 45 progammable keys depending how you look at it. a LCD screen for gaming and other sorts of stuff that you wish to mod. a good site for that is www.g15mods.com
  17. bumfluff
    18 Aug 2006
    I saw a black Saitek Eclipse II today in HMV, yes HMV, and it was only £25.
