Keyboard Woes
Discussion in 'Tech Support' started by jezmck, 4 Apr 2007.
  1. jezmck
    jezmck Minimodder
    25 Sep 2003
    I have a Microsoft Digital Media Keyboard 1.0A (apparently), and it's giving me grief. (I'd give a link but I don't think they do it any more)
    It has 5 numbered hotkeys, volume controls, keyboard/log off/sleep buttons, and a zoom slider.
    When I press the left Windows key it starts the calculator and occasionally brings up the start menu.
    The right windows key appears to do what the 3rd numbered hotkey should do.
    The up arrow key moves the cursor up then right.
    Probably some other issues too.
    I have the latest drivers.
    Any ideas on how to fix these?
  2. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Open it up and check the connections, sounds like crossed wires to me.
  3. jezmck
    jezmck Minimodder
    25 Sep 2003
    Absurdly, that would require the removal of 15 (fifteen) screws!
    Not that is difficult, but surely a touch OTT for a 10-quid KB.
    Plus it's only a few months old and I shouldn't need to. :grr:
  4. DougEdey
    5 Jul 2005
    Take it back to retailer.
  5. jezmck
    jezmck Minimodder
    25 Sep 2003
    I bought it online, and it's almost certainly not worth it.
    And I am just peeved that it is misbehaving so soon after buying it, no known damage, no spills, no nuffin'.
  6. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Mod it or get a new one? Hit it till it behaves?
  7. jezmck
    jezmck Minimodder
    25 Sep 2003
    just opened it up, couldn't see a single thing wrong, no corrosion, no fluff, etc.
    Hitting it till it behaves sounds good, but I don't think it'll work :(
  8. DougEdey
    5 Jul 2005
    Ring the etailer say that it's not worth you sending it back, complain a bit, they may just send you a new one.
  9. jezmck
    jezmck Minimodder
    25 Sep 2003
    Good idea.
    A polite start:
  10. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Try giving it a shake. Fixes mine when the "w" key refuses to work at the same time as "d" or "a".
    Shouldnt have to really though, as you've done probs best trying to get it replaced :)
  11. jezmck
    jezmck Minimodder
    25 Sep 2003
    If only it was that easy :D
