Electronics Keyless Entry
Discussion in 'Modding' started by Soljarag, 22 Jul 2005.
  1. Soljarag
    Soljarag What's a Dremel?
    22 Jul 2005
    Hey, I have a car spoiler in my room, and i bought a cheap keyless entry system to get it to turn on and off, and blink. So I hooked an old cell phone charger to power it, and I have it working exactly how I want. However when I turn on panic mode it makes a blinker sound. I was wondering if anyone has any tips on if i could disable this sound.
    The unit makes a beeping sound when you are configuring it, however this is a different sound than the "blinker" sound
  2. DarkInferno
    DarkInferno Minimodder
    28 Nov 2004
    Blinker sound? are you refering to the ticking sound you get when you indicate? is so that's a relay clicking.. replace it for a solid state... or remove the relay, but without the diagram I can't tell you what will happen in either case.
  3. Soljarag
    22 Jul 2005
    yeah, its the same sound when you put on your car blinker.. hmm.. I think i'm just going to live with the sound :) replacing the relay sounds complex
    edit- well, just curious, could you recommend a solid state relay (if you don't have enough information on this circut, just tell me one you "think" might work
  4. Krikkit
    21 Jan 2003
    It's not as complex as it sounds, I would guess it's quite simple. Try and find us a circuit diagram. :)
