Graphics KFA2 550 Ti White Edition Driver Installation failures
Discussion in 'Hardware' started by .//TuNdRa, 27 May 2011.
  1. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Just change the file extension, the only difference between .bin and .rom for bios files is literally just the extension.
  2. fireisdangerous
    fireisdangerous New Member
    2 Sep 2011
    Cheers. I got an email from kfa2 support and they have sent me a batch file to flash the bios.
  3. .//TuNdRa
    12 Feb 2011
    Glad to hear it's all sorted for you!
  4. bugmenot1
    bugmenot1 New Member
    23 Oct 2012
    Sorry for the bump. Could you upload the BIOS files again if you still have them.
  5. .//TuNdRa
    12 Feb 2011
    I've still got the cards, and I think I still have a backup of the original BIOS saved somewhere, although it will only work for this precise card, (KFA2/Galaxy 550TI White Edition) as it's a custom PCB and parts job.
    Gimme a few minutes to fish it out, although I'm really not responsible if your card does stop working because you're trying to flash an OC bios from another card onto yours.
    Edit; Okay. This is the BIOS dump straight off my first card. https://drive.google.com/file/d/0B0H3PcHsJy_vbEpDS2FVVnM4UVE/edit?usp=sharing
    I can't remember if I've fiddled with it or not, but it should still flash okay to any other White Edition.
  6. bugmenot1
    23 Oct 2012
    Worked perfectly. Thanks!
