Scratch Build – In Progress Kibako (Wooden box)
Discussion in 'Project Logs' started by legoman, 21 Apr 2026.
  1. legoman
    legoman breaker of things
    28 Feb 2010
    This has been ticking along for a while but blame Yuusou he suggested I do a build thread on this so Enjoy and endure. Also, as I am about 3/4 through so its a bit of a mess so apologies
    Also started as I wanted a fun WFH PC. So I lobbed together a little ITX build with what I had about. It then snowballed somewhat and evolved into an externally water cooled scratch build, because I'm an idiot and enjoy headaches.
    So, spec wise
    AMD 8700G
    ASROCK B850i ITX
    32Gb Corsair Dominator Titanium
    2Tb M.2
    160W Pico PSU
    This all started a couple of months back so my memory is a little fuzzy on parts.
    Basically I started out with a rough plan, I wanted a small ITX build and for some reason decided it was a smart idea to not only water cool it, which for a 65W TDP CPU is, daft. But externally water cool it (brilliant move totally wont be the bane of my life in a couple of weeks time)
    So doodling commenced. I hit upon a design I liked which is a variant of a type of Kumiko woodworking. Except I am not that good at it.
    Thankfully, I have a laser cutter! Many hours of design work later I have version one of the base (yeah that changed)
    This is made from 3mm frosted acrylic which is a slightly off black (Midnight black apparently) its very nice but needed a little more interest. Now initially this was going to be a mixed softline and hardline build which explains the hole you can see in the bottom of the case.
    This will be the front eventually. but space issues meant it was a no go meaning there was a void that served no real purpose, but I will show later that turned out to be very useful.
    With the setback of the mixed tubes/hosing aside I decided to start making some overlay panels. Idea here is to add some more strength to the piece as 3mm acrylic is not the strongest of things so some additional 3mm walnut plywood helps massively here. I added some Sakura like Kumiko here, this was taken during the laser process.
    The larger side panel evolved from one of the smaller parts after placing it on the case I decided to not add this and then add trim to hide some of the cables also adding some etching to mirror the pattern. This will lock on using magnets glued to both the side of the case and the underside of the panel. With this I thought it would use the Kumiko pattern for something it's used for quite often, which is lamps. Yeah, that void, its now going to be packed with LED strips.
    For the LED strip I went with a USB powered one. plan being to use one of the internal USB headers to drive this. It's also the same one I use for my monitor shelf light which lights the keyboard area on my desk and is also wireless. I've tested this and confirmed they work I can turn them on and off changing the brightness and colour temperature.
    Now with a side panel we want to look at the front. This was relatively simple just carry on the pattern and style to this and add a hole for a power button. It was also the perfect opportunity to show a lamp in there to see what happened
    Excellent! Its doing what we want. The front here is wrong I forgot to add 6mm to one side to come level with the top panel. Also the hole was 0.50mm too small, All part of the learning process. Also you have to consider I am designing this in 2D so it adds some additional messing about.
    At this stage we are quite close to the present state, and here is where I made a substantial change in terms of hardware. Initially I was going to use a 5600G with an X570i with 64Gb of RAM. But, I had the 8700G and board I was going to use for another project, which was a little silly as that will have a GPU. So all change and back into the laser software to re make the entire rear IO! To make this cleaner and because it looks cool I re made the rear IO in the software. being 3mm thick you can still plug everything in without issue.
    Faffing aside I turned started testing things, I noticed the pico PSU gets quite warm in use and it had no cooling so I added a panel with a large channel a channel for some cable to run and some 40mm holes for the cutest little fans, just look at them with their little fan grills!
    An yeah, I labelled everything internally you can see "ght tape" that is part of where the LED light strip will run. Plan with this is both fans blow back into the main body of the case pulling air over the PSU so happy PSU.
    This panel simply slots in. I have already cut some internal panels for this just I have no photos currently
    Now we are pretty much up to date. I have re cut the front panel and created the cable channel to hide the power cables and cables that run down to the external radiator.
    More to come soon, hopefully somewhat more coherent though!
  2. GeorgeStorm
    16 Dec 2008
    Need to update the permission for the photos I think.
  3. legoman
    28 Feb 2010
    Oops, yeah that should be working now!
  4. legoman
    28 Feb 2010
    Bit of an update as its all now glued together. Well, it was at least but I have pinged off a wood panel as I am debating a hole in the side which I will explain.
    But here we are at the moment, in this shot the bottom sits proud slightly, that was an error on my part which I fixed, I failed to add the stack height for the magnet when I fitted the magnet. I also took out a strip from the magnet to reduce the pull force. Its secure just doesn't mean you have to bend the thing to remove the side panel now.
    Waiting on some bulkhead fittings and black 90 degree fittings then I can actually plumb it up. Speaking off this is the radiator I will be using.
    Yeah, dual 80mm fans... These are the arctic P8 silent, so they run at their full speed of 1600rpm and they are silent basically. Radiator is 160mm X 60mm so beefy enough to deal with the APU.
    I mentioned a hole, this is because the little pico PSU gets a bit toasty I did have a plate with a pair of 40mm fans to circulate air but there was nothing direct onto the PSU so I am thinking a mount so the fan is facing the PSU like below. I can also drill a hole into the side but I think there would be enough coming from outside the case, seeing as there is no glass it has a big enough area with the main "window" to draw in from.
    ivory2k19, BeauchN and Cheapskate like this.
  5. Cheapskate
    13 May 2007
    It looks fantastic. Cabinet magnets are a bit clunky and overkill. You probably could have gotten away with gluing just the magnet to the case edge.
    Radiator box time?
  6. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    That's one nice wooden box
    legoman likes this.
  7. legoman
    28 Feb 2010
    Yeah they are somewhat chonk. I have some small rectangular magnets coming that "should" solve the issue for me. I'll just have to cover the inner parts where the glue marks are. Which is not a huge issue to be honest.
    Mean time I have been faffing about with a fan for the PSU so it doesn't melt on its own. I have 90% sorted an isolated fan mount which should mean I can run the fan at a decent speed and not have problems. Photos once the glue cures and I have tested it.
  8. legoman
    28 Feb 2010
    Well, been a bit. So. Kibako V1 failed it was basically a hot box of hell. The fan internally resonated despite being on isolator pads, back to the drawing board so to speak.
    New plan was, keep the overall vibe with the Kumiko pattern but I needed to make sure the thing wouldn't just cook itself. So into the design software and I came up with the below, this is the inner panels.
    So yes the cooling is now inboard, makes life easier overall for design and moving it about
    These are the outer skin panels, most parts are double layered for strength so you end up with 6mm thickness using clear adhesive spray on the wood side so you don't see any glue marks
    And here is the result, this was dry fit with the initial single layers to make sure it works. The loops on the top, these are because the top hinges open. Just make access overall much easier.
    The hole in the left front, thats part of the intake, I have a matched hole on the underside as we have a pair of 80mm fans in there and they need air to suck in.
    This is with the second set of panels that took a lot longer due to the pattern. At this stage it had been a coat of Danish oil, I think I ended up with three coats in all. Then finished with clear wax rubbed in with wire wool to get a nice sheen and flat down any rough patches.
    This is the back panel, yes its not in walnut, no I'm not changing it. So things to note. Lovely cut out for the radiator obviously, but also a little Sakura on the back to add some passive ventilation. and a huge M.2 cutout, means you can slap any heatsink on your like without any issue which is great.
    So this is stage one, testing it works really. Good news, all working happy and cool I had airflow running over the RAM and importantly the PSU. So in the bottom we have a pair of Noctua 80mm fans then in the top a pair of thinner Thermaltright 15mm fans as the thicker fans would collide with the PCIe slot on the motherboard.
    Temps came out great over all no concerns
    Final shots all plumbs and some panels to tart it up plus a little 3D printed velocity stack from Liquid Haus. So there is a plate over the rad fans extending across to the side of the RAM. It hides the cables, the annoying blue light from the PSU and helps control the air flow going up the channel, seems to work well
    Top I added the fan grill, its spaced above as it stops any fan chop noise also means I can change it out if I ever fancy something silly.
    Its sat on some HiFi feet, just basic black metal ones with a rubber ring nicely understated
    Loop wise its all pretty straight forward, though with hindsight I should have used a different type of temp proble. So placement wise its actually in the pump so its picking up the coolant temp after the CPU so it's always a little off. Really it should have been on the long hose coming out the bottom of the rad. Might be a job for the future.
    How's it run though? Well, it survived the recent heatwave max coolant temp of 43c CPU never went over 55c so its certainly working. Noise wise its pretty good, the pump is silent in operation so the only noise is from the rad fans.
    If I made it again, I would probably change a couple of bits, but overall extremely happy with this, it's very obviously a computer but it's visually interesting and with the laser cut pattern, the engraving and the heavily waxed wood it is very tactile. Hope you enjoyed, I have more stupid ideas cooking around in my head!
  9. Cheapskate
    13 May 2007
    Brilliant! :D Also, the slow trend back to 80mm fans means all my fan hoarding was not in vain. A FAT M2 heatsink integrated into the backplate would be awesome. -Possibly fitted with something 3d printed. I like how you think.
    The only thing I'd change is your image input. Switch to the "BB img" code to get the full images. I run my browser magnified and the images only show the top 1/3rd.
  10. legoman
    28 Feb 2010
    Fixed ;) yeah your right I should have used that to start with!
    Heatsink wise world is my oyster! I have one of those huge Thermalright ones, might be a bit OTT though. One thing I didn't mention is I initially ordered six 80mm Noctua fans so I do have two spare. I'm not returning them as they are a backup if things get overly toasty. Theres a slot on the back which was for a little D shaped piece I was going to make to help manage cables.
    Handy being 3mm wide means if I de pin a PWM fan cable it fits through so I could push pull if I really want.
    I don't think it will be needed It's been running all day and I currently have a core temp of 33.25c and a coolant temp of 42c, which is because it's on the wrong end of the loop. Touching the block hose and pump though, they are not warm and it's in the intake of from the CPU so, meh?
    Someone suggested I sleeve the CPU 8PIN cable. I have the correct sleeve, so Maybe at some point ifI get that bored. If I do I'll make a little comb to keep them neat and match the finish of the rest of the build
    Cheapskate likes this.
