Build Advice Kids PC
Discussion in 'Hardware' started by slambittech, 13 Apr 2020.
  1. Vault-Tec
    30 Aug 2015
  2. slambittech
    slambittech Minimodder
    17 Oct 2009
  3. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    Is there a decent alternative to StoreMI for older (Sandy) Intel-based systems?
  4. sandys
    sandys Multimodder
    26 Mar 2006
    you can do it all in windows 10 for free it is just a bit more manual, there is a thread on the forum, don't think you can do a boot drive from it but there is quite a bit of flexibility there as you can use a number of drives.
    https://forums.bit-tech.net/index.p...es-tiering-in-windows-10.336785/#post-4773673
    Or you can buy the software from entomus called fuzedrive it is cheap, under $30. AMD storeMI is a free version of fuzedrive.
    https://www.enmotus.com/fuzedrive
    Intel also has something called Rapid Storage technology too where you can use a small 60Gb ssd as a cache but it is not quite as good but can help slow an old hdd based system with a cheap sdd.
  5. ModSquid
    16 Apr 2011
    Ah, nice one - good work as always, Mr s!
    Will check it out.
  6. slambittech
    17 Oct 2009
    Actually seen articles for the new ryzen budget CPUs, they are looking decent for the price.
    4c/8t.
    Seems like it was a good thing to wait. Been looking for a 1600af daily but now will wait to see if it will be even cheaper or get the new ones.
    Still the gpu rx580 8gb models are at least £120 now a days for a good pre owned one.
