Killed my BIOS.
Discussion in 'Tech Support' started by Ending Credits, 4 Nov 2008.
  1. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    Well I flashed the BIOS of my DFI Lanparty 790FXB and now the computer wont even POST, LED display shows 88.
    Is there any solution bar an RMA?
    I've tried the CMOS reset jumpers and I've remove the battery with the power supply off for 10 mins (even tried shorting the battery socket as well).
  2. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    Ive had a similar thing with my DFI NF590. My workaround for that is the take the power out of the motherboard. Leaving the psu off dose not work. for about 10 mins. then it boots fine.
    I also believe that DFI will send you a new bios chip out. If you can not fix it.
  3. EnglishLion
    EnglishLion working for the good of mankind...
    2 May 2008
    There are websites that will sell you a pre-programmed replacement BIOS chip. Assuming that its a socketed chip and not surface mounted then you can peel off the sticker, tell them the details and email them the BIOS version you want on it. They will then send you a chip - obviously it'll cost you a small fee!
    http://www.biosman.com/
    Alternatively check your manual, there might be a blind flash option. I had an MSI board that could do that, you had to attach a floppy, put your BIOS (naming procedures apply) on a floppy along with a utility and then boot while holding down a key on the keyboard. It would then do an automatic re-flash - or so goes the theory, I never needed to.
  4. Ending Credits
    4 Jan 2008
    I found a connector seemably for flashing the BIOS but I don't have the equiptment to do anything with it. Could I try hot-flashing the BIOS in a different motherboard;would an MSI x48 board be able to do it providing tit had the smae kind of BIOS chip?
  5. EnglishLion
    2 May 2008
    doubt it and certainly wouldn't recommend it - but try at your own risk if you like I suppose.
  6. Ending Credits
    4 Jan 2008
    Well I ordered a new chip but it was the wrong size and now I think I've killed the original. Should I just contact DFI?
    Does anybody have a DFi contact link, I can't find one.
  7. Ending Credits
    4 Jan 2008
    Power light on but no power.
    Well I think I've completely killed my Lanparty DK 790FXB. The power light comes on on the motherboard but when the power or the onboard powerswitch is pressed nothing happens. The motherboard will come on when the PSU is shorted but won't POST.
    Is it completely dead.
  8. cpemma
    cpemma Ecky thump
    27 Nov 2001
    What have you done that could damage it? High voltage settings? Dropped from a great height? Flood damage? :confused:
  9. kenco_uk
    28 Nov 2003
    Re-do all the faffing about putting the cpu in, making sure there's nothing in the cpu socket or on the bottom of the cpu.
  10. Ending Credits
    4 Jan 2008
    Uh, mucked around with the BIOS chip (physical chip)?
    It seems well and truly dead and I've only had it a month. Going to see if they'll let me RMA it tommorow.
  11. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Two threads merged to avoid further confusion. :duh:
  12. Ending Credits
    4 Jan 2008
    Just to avoid confusion, this is with the new BIOS. (Actually I got two since one company sent a the wrong size so I made an order with a different company, both arrived on the same day :duh:)
  13. Kúsař
    Kúsař regular bit-tech reader
    23 Apr 2008
    Guess I'm a little late here - but 99% of good modern motherboards has some sort of "BIOS recovery". Even if BIOS flash fails for any reason, there should be way to boot into "safe-mode" & reflash it back. Just check manual carefuly. For example - on intel MB's there's jumper with which you can clear cmos, but if you remove it and power on your PC, it will try to recover from bad bios flash. Asus, MSI, GByte has something similar...
    I wanted to find some specific information on how to recover bios on your board, but navigating through DFI's web is piece of hell, especially with crappy wifi connection.
    The problems you described - "no boot" or even "no power" can be caused by bad BIOS(corrupted BIOS program - because it's partially active even before MB is switched on). Once you put in the right BIOS chip it'll work like nothing bad ever happened.
  14. Ending Credits
    4 Jan 2008
    Well, even with two different replacement BIOSes it didn't boot and it was botting with the bad one until something happened.
    EDIT: Thanks anyway, wish I knew all this earlier.
