Case Mod - In Progress "Killer HL Box" project by chatnoir Finished
Discussion in 'Project Logs' started by chatnoir, 7 Dec 2009.
  1. chatnoir
    chatnoir What's a Dremel?
    6 Dec 2009
    hi to all,
    come from Argentina to share my case mod "Killer HL Box" I hope to enjoy as I in creating it, thanks for this space;)
    The project is based on HL2 and out of an ordinary case, the most regular case, is my first mod, so be tolerant:D
    With an idea in mind, I decide to practice before with my old case, seduced me some forms to case but not all, but I needed to practice and make mistakes, wanted large windows and the paint had not decided, well ... Fasten your seatbelts
    we begin the flight, a very long flight...:dremel:
    see you later...
    bagman likes this.
  2. chatnoir
    6 Dec 2009
    hi,
    with the completed design of the windows, two inputs handmade and refine the entire surface, antirust paint base I had everything ready for the painting process:thumb:
    see you later...
  3. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    really digg the vents! :D nice work. keep it up!
  4. bagman
    bagman Minimodder
    18 Apr 2009
    nice vent that was so well done, it looks like it was meant to be there no lines around it at all looks great
  5. chatnoir
    6 Dec 2009
    really thanks pOPe, bagman I'm glad they're there...Wow apologies ... those who look to you also thanks.
    now look a little paint, a black base hammering, a few lines of industrial safety and oxidizeeed:lol:
    enjoy.. see you later:thumb:
  6. chatnoir
    6 Dec 2009
    hi,
    in the games there were places where you can spend and where you can not pass, also see irregularities on the metal oxide, I was always giving matt varnish to turn the brightness of the oxide, in grill with other small details oxide, alien poltergueist inside, blending with black. Based interior paint white to active poltergueist, Here, you may appreciate a little better the effect oxide, in my country do not sell paintings that are oxidized alone, so I had to improvise and create a "patina"... I'm attracted to cases oxidized, referring to this particular ... Imagine "was submerged long time and suddenly abruptly him out and put it in the sun at 50 degrees centigrade:rock:
    the next step is acrylic... chau:thumb:
  7. jrs77
    jrs77 Modder
    17 Feb 2006
    Good work so far.
    Looks really well matching the HalfLife-theme :thumb:
  8. Daedelus
    Daedelus What's a Dremel?
    7 May 2009
    Really nice paint job :)
    And I like the 'ruptured' vents too.
  9. chatnoir
    6 Dec 2009
    Hi, jrs77 and Daedelus:thumb:
    really thank you very much for commenting, I love they liked:rock:
    and now will see the preparation of the base of the mother and the acrylic, also a step by step from the back, the three supports of the psu and some more details
    see you later thanks to all:rock:
  10. chatnoir
    6 Dec 2009
    Hi to all
    Relaxing a couple of pictures and pictures of where I found the valve, another idea that was put on the head, a bit of work came out so good. open and close the case door.
  11. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Now thats cool, looking forward to finished item :D
  12. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    looking good. whatever you are using for texture makes it look like iron. and the rust looks great too, like iron rust. very rich and deep looking. whatever paints, techniques you are using it looks better than the self oxidizing paint i used in my mod. what a scrap yard you have access to, i bet you should find some other interesting things there for your case. keep up the work.
  13. chatnoir
    6 Dec 2009
    thanks coolamasta and lysol:thumb:
    if really in the junkyard I found incredible things, endless imagination flies, that's good ... the bad thing is that your brain never stops working ideas:lol:
    and now..the floppy was not in my mind to use it, but I needed a volunteer to make mistakes and test
    the next step... the DVD run, run for you life DVD :dremel:
  14. DeltaFX
    DeltaFX What's a Dremel?
    4 Aug 2006
  15. chatnoir
    6 Dec 2009
    Wow:jawdrop:, what a complicated mind of G69T's:lol: ... great work and great tools also.
    thanks for comment:thumb:
  16. chatnoir
    6 Dec 2009
    continue..
    that occur to them to do with this pack of mini discs
    and DVD show:thumb:
    a little weight to adhere :D
    thanks!
  17. MADKiller7
    MADKiller7 What's a Dremel?
    28 May 2005
    Very nice,i 'll be watching this log.
    I also use old stuff in my current mod.
    Imagination,lot of scrap stuff,minimal machinery and more handwork,the definition of pure modding.
  18. chatnoir
    6 Dec 2009
    Hi MADkiller7 thanks! and now look this...remember?
    do not miss the next step:thumb:
    Azayles likes this.
  19. Daedelus
    7 May 2009
    I really like this mod :thumb: I'm keeping an eye on it :)
  20. Jipa
    5 Feb 2004
    Good work! There's been a number of HL2-themed mods so it's not easy to stand out, but you're really pulling the theme off nicely. Keep it up, can't wait.
