Not really, but kind of.... well, this doesnt really compare to tthe real electronics work...but I need help.......... ok, the problem.... I have two of the toggle switches in the above pictures...Each one has two points to connect... I have two of the motors in the picture.....(there are two there) so, each one has two wires...a posative and a negative.... ok, so what i need to do is connect each motor up to its own switch....and then get power to them all..i have the necessary battery "holder" which also has a posative and a negative.....so how will i connect each motor to a switch while giving them power.... I appologize in advance for the N00B question.....but I appreciate the help... -Cereal....... -
.....well, they work for me...... -should be better now......maybe not -if they are still dead...then lok at the properties, and go to the link....i will put up the links for the lazy people in a little while....
IMG will be available for ~14days thing at bottom, thats the battery. M = Motor. Just connect both the negatives together to the battery, then the switches as shown.
Success!!!!! It works, thanks alot man...this will be awsoem when it is done....i might do a project log.....this is really a practice for my "maxx cool" case mod.............
