News Kingmax unveils invisible heat sinks
Discussion in 'Article Discussion' started by CardJoe, 9 Jun 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    That is utter bull-hit. Everyone who has studied just a bit of physics know that you need to maximise the surface layer, not fill out all the cracks with super-nano-goo.
  3. Glix
    Glix Left Thumb Stick in the mud.
    11 May 2010
    The king's new clothes have arrived xD
  4. Zayfod
    Zayfod What's a Dremel?
    6 Jun 2005
    So it's like a wicking fabric, only nano, invisible, and for heat? Could work I suppose, if you happen to live in "Physics Experiment Land" where every process can operate in neat isolation from every other process.
  5. eddtox
    eddtox Homo Interneticus
    7 Jan 2006
    Hahahaha... Well that's nothing compared to MY invisible, intangible cooling solution which may reduce CPU temperatures by 20 degrees when coupled with an approved heatsink cooler. Only £9.99. Call 1-800-GULLIBLE and ask for a wake-up call.
  6. mi1ez
    mi1ez Modder
    11 Jun 2009
    Sponge. Great insulator. Poor metaphor.
  7. Xir
    Xir Modder
    26 Apr 2006
    That's probably what ist does, maximise surface area on a nano-scale
  8. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    Sounds like a gimmick. Will have to wait until bit tech/custom pc get hold of some for review.
  9. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    So to save money they arent putting aluminium spreaders on them and to justify it there using a solution that cant be seen?
    are kingmax nigerian by any chance?
  10. BlackMage23
    BlackMage23 RPG Loving Freak
    4 Aug 2006
    Hey, I just invented an invisible CPU, any buyers?
  11. tristanperry
    tristanperry Minimodder
    22 May 2010
    Sounds like a gimmick. Will look forward to the reviews though.
  12. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    My invisible heat exchanger is a thing called "Oxygen"
  13. StoneyMahoney
    StoneyMahoney What's a Dremel?
    10 Jul 2009
    So, basically it's a kind of pre-applied TIM using the surrounding air as the dissipator? Judgment reserved until independent figures released. Could be a game-changer, more likely to be a white elephant.
  14. Claave
    Claave You Rebel scum
    29 Nov 2008
    Unfortunately, DRAM chips don't have thermal sensors, there's not much chance of being able to verify the technology. I suppose you could apply the goo (?) to something that does have a thermal diode, but as those chips require large heatsinks to keep them cool, we're into the realms of TIM testing and that's a whole can of worms...
  15. Sheiken
    Sheiken Wat?
    9 Jan 2005
    I sell invisible gold and diamonds, genuine goods I swear!
  16. Mraedis
    Mraedis Minimodder
    5 Sep 2009
    Are you familiar with the physical properties of a sponge, good sir? It's maximized surface to mass ratio! Goodness me.
  17. Deadpunkdave
    Deadpunkdave ...why you need a 20-sided die
    9 May 2009
    And anyone who knows a bit of nanophotonics will tell you that nano-scale structures have a tendency towards phonon confinement, thus decreasing thermal conductivity. Since the engineers probably aren't completely incompetent, I would suggest that they have found an application with the reverse effect. It's quite amazing the number of people who seem to have decided that 'if you can't see it, it doesn't work'.
    Presumably, you are a fan of explosions inside your pc case? =p
  18. DriftCarl
    DriftCarl Minimodder
    2 Nov 2004
    wonder if I can buy them using my revolutionary invisible £20 notes
  19. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    The key issue is that if the coating will survive installation.
    Gripping the coating and attempting to shove the RAM stick down = no more coating.
  20. ZERO <ibis>
    ZERO <ibis> Minimodder
    22 Feb 2005
    So they claim that they made a thermal paste so efficient that it by itself is better than a decent HT with shitty thermal paste!? If this is true I am surprised they are not coming out marketing the paste. I mean if it is that good I want to put it on everything!
Tags: Add Tags
