News Kingston is first to DDR2-800 3-3-3
Discussion in 'Article Discussion' started by Tim S, 21 May 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Paradigm Shifter
    10 May 2006
  3. completemadness
    completemadness What's a Dremel?
    11 May 2007
    So you can pay £5 less and only occupy 1 slot instead of 2 .... - am i missing something ?
  4. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Unless they're 2GB sticks at CAS3, this news is well and bunk. Everybody's been offering these latencies for a while.
  5. Guest-16
    Guest-16 Guest
    Nope, not 3-3-3. Most "CAS3" modules are only rated for 3-4-4-*, although they will do 3-3-3-* :)
  6. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    I think i will stick with 1.9V to run at 800Mhz 4-4-4-12 (my motherboards max is 1.95 anyway :waah: )
  7. Tulatin
    16 Oct 2003
    So Kingston wins a newsworthy title for binning some chips and tweaking some synergetics? Sad.
    As to your plight teamtd, why not voltmod? Had to for my P5B (no volts above 2.1 otherwise)
Tags: Add Tags
