Hardware Kingston SSD NOW V+ Series 128GB Review
Discussion in 'Article Discussion' started by Lizard, 17 Feb 2010.
  1. MitchBomcanhao
    MitchBomcanhao New Member
    21 Jan 2010
    yes I understand, my own desktop takes a while going through the sata/raid stuff, but the actual OS booting time is fast.
    i really don't care about cold boot times, though, as i always hibernate my pcs, which is much faster.
  2. FelixTech
    FelixTech Robot
    12 Jun 2009
    As long as you can select your team before 'Waiting for players' ends, what else matters? :p
  3. frontline
    frontline Punish Your Machine
    24 Jun 2007
    Glad i purchased my Crucial M225 just before the price hike started. The windows boot times are impressive and particularly noticeable when installing updates etc, but the main benefit is just the overall impression of system responsiveness when compared to a HDD.
  4. kenco_uk
    28 Nov 2003
    Does the X25-M feel so much faster than a Vertex? I feel as though it's six of one... with the Vertex you're getting 'higher' write speeds, but Intel's offering, from various places on the net, is said to feel so much faster. Does it really just boil down to the random access speeds?
  5. Skiddywinks
    Skiddywinks Member
    10 Aug 2008
    Basically. Sequential anythings are only really useful for copy/writing files.
    I have an X-25M G2 160GB, and the only times I can think of when I would be outpaced by any other SSD is when copying something to it, but then you are more likely to be limited to the read of the other drive, so unless that is another SSD, you have no reason (other than price difference) to not go Intel.
  6. Makaveli
    Makaveli New Member
    25 Nov 2009
    Amen Brother,
    I went X-25M G2 160GB and never going back. My previous Windows install is on a Western digital 640GB drive and you can feel and see the difference as i dual boot both for the time being. Also helps to show doubters why the SSD was worth every cent. For some of the the graphs will never do you justice you have to use a system with an SSD. It also depends on how you use your computer if you just browse the net and use one application at a time then stick to a platter based Hard drive.
  7. Xir
    Xir Well-Known Member
    26 Apr 2006
    For me the price is too high as well, we can only wait for nand-chips to become bigger, so less are needed for 128GB drives.
    True, the companies are just about breaking even...don't forget the quimonda shutdown that helps push prices up.
  8. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    I just got me a couple of the 64GB V+ variants running RAID 0 with a clean install of W7 and they seem fast enough to me.
    I'm going to try one in single drive config as i'm sure running RAID 0 is a waste for me and the apps i run and would rather use the other in another machine.
  9. barrkel
    barrkel New Member
    31 Jan 2007
    Ah, but I have a plan for that - I'm going to buy the G2 soon enough, and low-level format the G1 and put it in my laptop...
  10. Guest-16
    Guest-16 Guest
    :D
    G2 or Sandforce.. or Indilinx?
  11. eXpander
    eXpander New Member
    17 Nov 2008
    An SSD experience cannot be described by numbers only. You have to "feel" it, to see for yourself how your system operates when it's stored on an SSD. Then and only then you'll be a true believer. You CANNOT go back to booting/operating from a mechanical HDD, without tearing out every single piece of hair from your head (if you have any).
Tags: Add Tags
