Hardware Kingston SSD NOW V+Series 64GB SSD review
Discussion in 'Article Discussion' started by Claave, 16 Oct 2009.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. stonedsurd
    11 Mar 2009
    The Samsung controller is still a letdown :(
    Ah well, the OCZ Agility series is pretty decent value.
  3. Xir
    Xir Modder
    26 Apr 2006
    Couldn't this be solved by making the SSD you windows/cache drive, while installing your games on a "normal" harddrive along with your data?
    (I anyway never install my games under C:\program files...)
    Xir
  4. Claave
    29 Nov 2008
    Yers, but then you don't get lightning-quick game level loads - I guess it depends on how much gaming you do, and how much you hate the waiting for levels to load.
  5. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    Looks pretty impressive for the money. Is there a Crucial M225 128GB review on the way?
  6. Tyrmot
    Tyrmot What's a Dremel?
    12 Mar 2008
    I've been trying to decide what's the better choice (for gaming) out of the X25-M or one of the Indilinx SSDs... Anyone got any thoughts they want to share?
  7. Baz
    Baz I work for Corsair
    13 Jan 2005
    we're waiting for the Windows 7 firmware update. It's an Indilinx based drive for cheap tbh, and if you can stand to wait a week or two for firmware updates over the Vertex, it's the best Indilinx drive - they're all the same after all.
  8. Baz
    13 Jan 2005
    Indilinx Indilinx Indilinx
    The new firmware (available now to OCZ vertex users) enables TRIM support too, so excellent performance maintenance in Windows 7. We tested both the old and the new X25-Ms for Custom PC's labs test, and while they have the best random write speeds (30+MB/s) theier sequential write speeds are cack - 80MB/s is slower than a hard disk.
    The Intel drives also loaded the Crysis level a couple of seconds slower than the Indilinx based drives. While I know the Intel drives have their fans, I'd take superior real world and massively faster sequential writes over un-noticeably faster random writes any day.
  9. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    i want an ssd so bad. thing is i'm not about to pay more than about this price, but i'd be wanting at least 100gb. looks like i'll be skipping a generation.
  10. Tyrmot
    12 Mar 2008
    Ah ok cheers Baz. The Intel has the advantage of coming in at 80GB at the ~£170 point where the various Indilinx types seem to be 60-64GB for a similar price, and I'm don't have the £££ at the moment to move up to the 120-128GB versions... But I guess performance wins this particular race
  11. TS_Slick
    TS_Slick What's a Dremel?
    16 Oct 2009
    OK maybe im missing something but a "Kingston Technology 2.5 inch 128GB SATA2 SSDNow V-Series Drive " on amazon costs "£167.19 & this item Delivered FREE in the UK with Super Saver Delivery. " sorry for the advertising but SSDs prices change by the minute and even though this one is on back order (upto a month apparantly) thats still a heck of a lot cheaper than any other one ive seen on this site.
    And yes ok theyre indilink or whatever but so what, whatever you buy in new technology you'll get bugs, just depends on how much you want to spend to find out those bugs.
  12. Primoz
    Primoz What's a Dremel?
    22 Dec 2007
    Is 60 gigas ACTUALLY not enough for WIn 7? I have a 25 gig partition for my XP with some ranom, non-essential programs installed there as well, and i still have over 8 GB of space left.
  13. Baz
    13 Jan 2005
    That's the V Servies that uses the old JMicron controller, not the V+ that uses the superior Samsung. The standard V series is completely rubbish, as as such is priced to ship, although I'd feel sorry for anyone foolish enough to grab one - time to write 1.6GB of ISO files? 46 seconds (36MB/s). Maximum random write latency? 1615ms (yes, that's 1.6 seconds!).
    I'll admit they're confusingly named though - it'd be easy to get mixed up, especially as the drives are worlds apart in terms of performance.
  14. Primoz
    22 Dec 2007
    The one on this site is V+ ;)
  15. BigM2006
    BigM2006 What's a Dremel?
    8 May 2006
    **Cheers, Fixed**
  16. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    I edit video for a living.
    The thought of an OS randomly grabbing hard disks outside your control is... well, I was going to say "very worrying", but in actual fact, it's a complete deal breaker.
    I presume this, along with whatever other new stuff they've dreamed up, will go on the list of Things To Switch Off Immediately After Install. Honestly, since windows 98 the only user experience thing that's actually changed, with a slight nod to stability, is the amount of crap I have to turn off on install.
  17. Baz
    13 Jan 2005
    wrong thread there phil?
  18. Phil Rhodes
    27 Jul 2006
    You just pressed my "OS knows best" button.
    Again can we turn off this "randomly grabbing hard disks" thing?
  19. Toka
    Toka Minimodder
    19 Nov 2006
    Im posting this from windows 7 on a 60 gig partition, and it runs just fine. Mind you the only things I have installed are security stuff, flash et al for browsing, drivers, some stuff for VNCing to work, and DEFCON for when I cant be arsed to VNC to work.
    Probably he means that 60g isnt enough for W7 and your Steam folder :)
  20. Guest-16
    Guest-16 Guest
    You what?
Tags: Add Tags
