Blogs Kingston won't provide firmware updates for recent SSDs
Discussion in 'Article Discussion' started by CardJoe, 16 Mar 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. mi1ez
    mi1ez Modder
    11 Jun 2009
    Deary deary me...
  3. stonedsurd
    11 Mar 2009
    Frimware?
  4. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    The current Indilinx controller is great, but in SSD terms it's quite old now. When will we see a new, even better controller from Indilinx?
    I'd like to see an SSD that actually needs SATA 6gbps.
  5. Ross1
    Ross1 What's a Dremel?
    15 Feb 2009
    If you are going to buy an SSD, you might as well buy a good one, i really dont see the point of getting these cheap knock offs.
  6. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    Then again, I remember Intel dropping support for first gen X-25M's which to my knowlegde wasn't exactly a ultra low-end budget model. Correct me if I'm wrong.
    Just something to consider before diving headfirst into SSD world.
  7. Guest-16
    Guest-16 Guest
    That's true. Intel dropped the G1 as fast as it could. It's partly why recommend Indilinx: consistent, reliable support.
  8. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    i could recommend only the Indilinx based SSDs, (OCZ crucial or the other one that i cant remember, as they are on the first come first support list {partner} so they get updates quite fast, others can take months or maybe never)
    if intel had done what they should of done and made an firmware update for there G1 SSDs would of been an good buy, the Kingston hack is really not that hard
    Samsung are bit Quite when it comes to SSDs, at least they added TRIM support to there second gen SSDs as that would of got corsair really messed up and a lot more unhappy users then there are all ready (still need to fix the Write latency)
    Toshiba i think do make there own SSDs now (not JMicron or was it the New *Fixed* 612 that now has cache thats now used?)
  9. nitrous9200
    nitrous9200 What's a Dremel?
    4 Oct 2007
    Well, there's another brand to add to my do not buy list.
  10. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    shoulda got an intel drive for all those that got this :p
  11. mull
    mull What's a Dremel?
    22 Sep 2006
    Pretty pathetic customer support on Kingston's part :/
Tags: Add Tags
