Storage Kingston's HyperX SSD
Discussion in 'Hardware' started by Yeoo, 14 Sep 2012.
  1. Yeoo
    Yeoo Minimodder
    1 Sep 2011
    Ok forgive me but since I left the IT industry 9 months ago I have become out the loop.
    I am after a SSD and have a soft spot for the Kingston HyperX series...
    Now I'm confused as I can see 3 different 120GB at different prices, what's the difference?
    http://www.scan.co.uk/products/120g...lc-flash-read-555mb-s-write-510mb-s-85k-iops-
    £80
    http://www.dabs.com/products/kingst...ve-upgradekit-829S.html?q=hyperx 120gb&src=16
    £130
    http://www.scan.co.uk/products/120g...81-mlc-read-555mb-s-85k-iops-max-upgrade-bund
    £130
    Confused
  2. Deders
    Deders Modder
    14 Nov 2010
    I think the cheapest one is OEM, the others come with packaging and added extras.
    not exactly sure how it "increases frames per second (FPS)", might help when streaming between sections but it's still a bit of a leap.
  3. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    It's all the same ssd, but as deders said, the more expensive ones come with stuff like external enclosure and cloning software and stuff. Unless you think you really need those things then the cheaper base ssd only is the way to go.
