Modding Knightrider/HDD meter
Discussion in 'Article Discussion' started by macroman, 22 Jun 2002.
  1. macroman
    macroman The One
    3 Sep 2001
  2. NuTech
    NuTech Minimodder
    18 Mar 2002
    OMG, Macroman. Those guides are truely excellent.
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    What a cunning plan, not a logic chip in sight.
    Like it, bossman. :D
  4. CharlieCat
    CharlieCat What's a Dremel?
    12 May 2002
    I just have to have a go at making one of these for my machine but I have never made a PCB before.
    Any advice as to where to look for a tutorial ? and where to get the equipment/parts needed ?
    Excellent work Macroman, keep it up !!!
  5. Pachena
    Pachena What's a Dremel?
    13 Jun 2002
    Macroman,
    Thanks for the great guides.
    Even though I can't see using these particular mods in my current project, I read them again and again (my plans are always subject to change).
    I especially appreciated listing Hosfelt parts, for us folk on this side of the big pond.
    Mark.
  6. flibble666
    flibble666 sorry i am dyslexic
    7 Apr 2002
    well the old days are back and in my pc
    shame i made one just like this for a 1st year college project and put it in a mates car and used blu leds in sted but hay its still very good work and connecting it to the hdd activity is grate
    why not put the leds on a seprate bord that attches with ribon cable and have a green/red/blue/and/yello
    led boards
    thining of the old days take a look here http://www.yesterdayland.com
  7. flibble666
    7 Apr 2002
    hay macro any chance of geting the 10 individual led 10 individual led version pcb
    on page 1 in the atchial size for printing
    u no my msn contact me on there........
    also the correct size cathode throbber pcb lay out
    as i only have a week left at college i need to print pu all my pcbs
  8. macroman
    macroman The One
    3 Sep 2001
    The foil patterns are 4x size so they print sharply when reduced during printing. Actual size will produce poor prints.
  9. flibble666
    7 Apr 2002
    ok thanks so do i reduce the when i put them on to trannsparcy and i guess this is the top viw so it needs prnting backwords
  10. macroman
    macroman The One
    3 Sep 2001
    no print it as seen so the ink side touches the etch resist. It is shown as if you were looking through the top of the board.
  11. FragSyndrome
    FragSyndrome What's a Dremel?
    13 Jan 2002
    Wow... very, very impressive.
    Although I think that your cathode throbber circuit was the best off all, this one has the best written article.
    Anyway, I've got a great idea of how to make the effect even better... fiber... stick some 2mm fiber into the leds and then cram the fiber virticuly into a 3cm area (2mm per LED, 1mm between each of them). I think that the best color combo would be (from bottom to top) 3 white, 3 blue, 4 red; OR 4 white, 4 blue, 2 red (I'm too cheap for that one though)
    the problem is, I lost the name of that really cheap fiber supplier in the USA when I reformated, could someone please send me the link if they have it? FragSyndrome@hotmail.com
  12. ^KoC^R@
    ^KoC^R@ What's a Dremel?
    28 Apr 2002
    hey macroman, nice guide
    could you make also one for cpu activity and soundlevel?
    (cpu not on the par port plz :), i don't have any)
    :beg::beg: ;)
  13. flibble666
    7 Apr 2002
    thanks macro i gess its the same for the throbber pcb and its the linked pic thats 4x bigger yes
    whot do you use to etch fluid or a tank as i am leaving college soon and need to make more circuits and i hate strip board (i made a light box )
  14. flibble666
    7 Apr 2002
    hay mate soundlevel circuits are all over the net do a google i mad one for a mate if you can get access to one of those plasma balls(lamps) thay have one in and if its a bust one tha run off 12v so just use that (unless its that bit thats broke) ;)
    p.s. if its not brok be very carefull the ball is very thin i broke mine :cries:
  15. ^KoC^R@
    28 Apr 2002
  16. flibble666
    7 Apr 2002
    this will help me thinks loads of vu meaters
    http://www.discovercircuits.com/V/vu-meter.htm
    look for one with an audio jack in (headphone type connector) just add a female connector to the in put and run a male to male make from your sound card
    macro may help u more he may have more knowlage of these types of cricuit or even mail the onwer of that website
  17. x24
    x24 What's a Dremel?
    9 May 2002
    Woohoo! It's about time. but no fading trail effect?
    question though. how many volts does the circuit supply on each LED? What if I was to use a 3.5v LED on there. do I need to adjust any resistor values or something like that?
  18. linear
    linear Minimodder
    5 Oct 2001
    No worries about the voltage. But it does only sink 10 mA of current for each output, so as long as your LED will light up with a 10 mA drive current, you're ok. Just don't think you can parallel several LEDs on the outputs.
  19. flibble666
    7 Apr 2002
    good timing i was just aboot answer that
    shame moast led are 20ma
  20. macroman
    macroman The One
    3 Sep 2001
    I did originaly design it with the fading trail effect but considered the increased component count and complexity didn't warrant it for a simple project
Tags: Add Tags
