Cooling Kuhler H2O 920 Over Ultra Extreme 120
Discussion in 'Hardware' started by ComputerKing, 8 Dec 2011.
  1. ComputerKing
    8 Sep 2006
    Hello...
    Someone Offering me Antec KUHLER H2O 920 Liquid Cooling System Used for 2 months for 100$... I already have Ultra Exterme 120 And MY Current System on the Sig...
    Is it worth it ? Noise and Cooling Will be effected that much ?
    Thanks
  2. fractal arc modder
    fractal arc modder What's a Dremel?
    12 Aug 2011
    Hey yeah they are good but not as good as good as the Corsair H80 and once installed be prepared for a turbine noise until you configure the Antec software and install the usb cable to the usb header.
  3. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Cooling will be better, but some good fans will help :)
  4. ComputerKing
    8 Sep 2006
    I will Replace The Fans With Enermax Clusters... And I think I will Control them to one speed 1.2 K .. Should that be a good option over the antec fans ?
