Other KVM switch.
Discussion in 'Hardware' started by Kronos, 7 Mar 2018.
  1. Kronos
    Kronos Well-Known Member
    6 Nov 2009
    To create more playing area for the Oculus Rift I find I have two PC on one desk near enough and feel that a KVM would be useful.
    Can anyone recommend a good one that works with windows 10?
  2. Vault-Tec
    30 Aug 2015
    Windows is irrelevant it does not have a controller.. I have a couple, but sadly no pics and I am away from home ATM. If you find some run them by me, as I had a bit of trial and error finding decent ones. Note though, you won't be switching the video unless you want to spend a fortune.
  3. Kronos
    6 Nov 2009
    No just keyboard and mouse I have the monitors set up just fine.
  4. Vault-Tec
    30 Aug 2015
  5. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    If you just need keyboard and mouse switching, and can leave at least one PC powered on when you are using both, then an entirely software solution like Mouse without Borders or Multiplicity would work. Otherwise, any basic cheap USB K/M switch would work if video switching is not required.
  6. Kronos
    6 Nov 2009
    Bought Andy's recommendation. Thanks both.
    Vault-Tec likes this.
  7. Vault-Tec
    30 Aug 2015
    It should auto switch (and usually does) but sometimes you just need to press the clicky button :)
