Other L Shaped Desks
Discussion in 'General' started by Pieface, 10 Jun 2013.
  1. Pieface
    Pieface Modder
    8 Mar 2009
    Hey guys, I've moved back into my normal home, and the current desk is too small. I've got a corner of the room I can fill out, but trying to find a decent desk is difficult.
    I want it to flow around the walls (Where I can put the monitor (hopefully 3 in the future) in the corner bit, but just looking for ideas if anyone knows any. I don't really want a really wide desk like the Galant desks from Ikea.
    So just looking for ideas of good desks for around £150
    If you guys have L Shaped desks I'd love to see examples!
    Thanks
    (Dimensions don't matter at the moment so much, as it's just for ideas.)
  2. Krikkit
    21 Jan 2003
    Build it!
    Couple of nicely cut sections of kitchen worktop and some supporting framework, anchor it to the wall and away you go. :D
  3. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    From Ikea its the Galant range. Had it for 10 yrs they're brilliant.
  4. suragh
    suragh Derp
    26 Nov 2011
    If you are going to buy a pre built/flat pack desk, go for an Ikea Galant.
  5. itrush07
    itrush07 Minimodder
    28 Nov 2007
    Awesome, need that kind of desk also for my not so big room.. hope to get one real soon.
  6. October
    October Mariachi Style
    20 Jul 2009
  7. Pieface
    Pieface Modder
    8 Mar 2009
    Is there another Galant piece that can attach to the small bit you see on the right side of the picture?
  8. Cei
    Cei pew pew pew
    22 Mar 2008
    Yes. Galant desks can be expanded on all sides. My Galant is in storage, but they are good desks.
    Currently I went the kitchen worktop route, and it is awesome.
  9. Kovoet
    26 Aug 2009
    With Galant you can add on. Go on their website and check it out
  10. GaryP
    GaryP RIP Tel
    31 Aug 2009
    I just got 3 basic ikea desks (vika amon?) with 12 legs.
    Works a treat. I have a ushape desk :)
    Edit:
    They changed them... now called Linmonn and legs are Adils
    Mix what you want.
  11. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    If you don't want the Ikea look, investigate some secondhand office furniture places - they quite often have corner desks - I have one at home that I took from my office when we closed it down. Works perfectly, although it is probably suffering from not being polished every night ;)
  12. fuus
    fuus Rocking All Year Christmas
    4 Dec 2010
    +1 for Ikea Galant!
    Teelzebub likes this.
  13. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    This,
    I think you have your answer.
  14. wolfticket
    19 Apr 2008
    2nd this (as an alternative at least).
    Professional office furniture is often built to a higher standard than consumer stuff and is sometimes replaced while still in very good condition. If you're lucky enough to find something suitable you can get expensive office furniture for a fraction of what was worth new.
    My chair and desk were quite a bit cheaper to buy than the Ikea equivalent but would have cost many times more new. Ikea stuff is okay, but you can really feel the difference in quality.
  15. fuus
    4 Dec 2010
    I'd advise looking on eBay before going and buying Ikea desks. I got my Galant worth in the region of £140 new for £20! Obviously you'll need a method of transport though!
  16. dombooth
    dombooth What's a Dremel?
    7 Jun 2013
    Ikea Galant L desks are great, got 2 in my office.
    Dom
  17. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    I have an L shaped desk. Mine was 35 quid, gumtree. It is a beech sort of colour. My chair was a similar purchase cost less than 20. The only issue with my desk is a bit of wear and slight scratching to the surface. A lot of which is probably caused my me and Mrs bears wedding rings or watches catching the surface.
    I'd definitely recommend ebay, gumtree or preloved or your local free cycle group before buying new. I love a lot of Ikea stuff but part of me thinks it is damned expensive for what it is. Effectively a chunk of wood (probably MDF) and a few metal legs. Hence I went down the previously used route and I'm more than happy with the result.
  18. Kovoet
    26 Aug 2009
    I know what you mean but I've had mine ten years so it was worth it
  19. dancingbear84
    16 Oct 2010
    I don't doubt it will last but the thrifty bit of my brain says wood shavings+glue+laminate cover+some metal legs does not equal £1xx
    But to be fair I am tighter than a duck's ar*e. I buy most my stuff on special offers. My tv was a richer sounds clearance, tablet a Tesco boxing day special so I'm not the best person to ask advice from.
  20. Kovoet
    26 Aug 2009
    I wish I had that problem bud trust me. Money always burns a hole in my pocket.
