Case Mod - Complete ⭐ L3p - SteigerWood - Liquidcooled Gaming HTPC - Finished!
Discussion in 'Project Logs' started by l3p, 19 Jul 2015.
  1. l3p
    l3p www.^.nl
    1 Nov 2010
    Back to business :)
    In the meantime I used the old PSU and SSD for other projects so I was really happy to receive new parts.
    I also received a very nice fan grill from MNPCTECH. The same as I still had from a previous project.
    And finally .. a custom length cablekit for the SF600
    Safes a lot of time time :)
    Not sure yet if I'm going to use the cableclips as they are very short
    So, lets figure things out
    Always a bit scary with 5mm brushed anodised aluminum.
    Fits!
    Also changing the little usb/audio cover under the reservoir
    And the top
    By removing this it will have no spacing.
    Some transparent glue to be sure
    Quicker drying :)
    More airflow for the bottom
    And changing the backside
    Lots of drilling, sawing, filing and sanding
    And done again
  2. arduum
    arduum Minimodder
    10 Mar 2015
    l3p
    omg 5mm [​IMG][​IMG]
  3. l3p
    l3p www.^.nl
    1 Nov 2010
    That's what I love these cases for :)
  4. l3p
    l3p www.^.nl
    1 Nov 2010
    Mounting time!
    First the 4 standoffs for the mainboard. Using a long marker for it.
    Creating my own standoffs from aluminum pipe and long bolts as the bottom panel is to thin for standard standoffs
    Painting the shiney aluminum matte black as I don't want any light going in or out.
    Also had to shange the fans to make them fit with the top panel.
    Sturdy rubbertape to seal the radiators airflow
    And mounted them from the bottom to the case.
    Also used rubbertape on the reservoir to prevent any light going out from the inside of the case
    This was just an idea to keep the reseroir horizontal.
    But as how I usual work, changed my idea, using the aluminum pipe again and found some longer M3 bolts so I can also mount the reservoir.
    Did a lot of other small boring adjustments to make it all fit ... but I succeeded :)
    And then ... the cables
    Took me a while but also got it done. Only still need to sleeve the pump PWM cable
    The SSD was just as wide as the EK GTX970 block .. thought it was a nice spot and it gets cooled a bit too :)
    Next update .. the loop.
  5. l3p
    l3p www.^.nl
    1 Nov 2010
    Finally a summervacation update.
    After one and a half week I couldn't hold it anymore .. picked up my casemod to work on it in the sun in front of my caravan :)
    First some covers for the back.
    Also gave them some color in my special paint cabin
    Also changed some connectors and cable sleeving.
    Finally starting on the loop.
    And some more sleeving and cablemanagement.
    Loop is starting to get shape.
    But finally ..
    Back home some packages were waiting.
    Sleeved power and network cables from Cablemod
    And the gaming gear by Corsair
    Just need to assemble it.
    So later on I will be able to game from the couch :)
    Next update .. filling it up!
    First had to check it again how it would look.
  6. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    I love how aristocratic that cat looks. :D Build is looking awesome! You must have played a lot of Tetris as a kid, since you seem good at stuffing things into tight spaces. :)
  7. shokka9
    shokka9 What's a Dremel?
    10 Dec 2015
    It didn't look possible to get all that gear into one of these; but you did it, and you did it well.
    Looks really good.
  8. Hukkel
    Hukkel James' minion
    20 Dec 2012
    It looks like a maze of chrome pipes. Very nice Peter !!!
  9. Vault-Tec
    30 Aug 2015
    Awesome work there. Talk about a wedgie !
  10. l3p
    l3p www.^.nl
    1 Nov 2010
    Exciting to finally fill it up!
    No leaks so first boot :)
    Still decided to change some about the lighting as I could see a few leds when sitting in front.
    CPU and GPU 60 degrees stressed, not bad.
    Next time, final pics!
  11. Hukkel
    20 Dec 2012
    Looks superclean Peter! The 2 fans with the filters on top almost look like speakers now ;)
    Loving the maze of chrome pipes inside :)
  12. Nexxo
    23 Oct 2001
    I note that RAM block has barbs coming out the side rather than the top? New EKWB model?
  13. l3p
    l3p www.^.nl
    1 Nov 2010
    Thanks Tim! :thumb:
    It was custom made by Parvum and JR23 :)
  14. C4B12
    C4B12 Minimalistic PC's
    6 Oct 2011
    Awesome job Peter! Where do I order one? ;)
  15. Nexxo
    23 Oct 2001
    That would solve a problem for me. Seconded.
  16. l3p
    l3p www.^.nl
    1 Nov 2010
    It took quite some time, but finally .. Steiger is done :)
    Happy new year all!
  17. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Damn man, you do such fantastic work! :rock: Great job sir!! :rock:
  18. Yaka
    Yaka Modder
    26 Jun 2005
    very much a top job.
    your threads always make me want to take up modding again. sadly i just dont have the time any more.
  19. l3p
    l3p www.^.nl
    1 Nov 2010
    Thanks Bartacus!
    Thanks! And just start man, I also took a year for this project :)
  20. Hukkel
    20 Dec 2012
    Great work Peter. Well done. One kick-ass gaming htpc
