Scratch Build – Complete L3pipe - Bit-tech Scratch Build Of The Year 2015
Discussion in 'Project Logs' started by l3p, 23 Nov 2014.
  1. l3p
    l3p www.^.nl
    1 Nov 2010
    Thanks guys, appreciate it!
    Trying to be different with a build is hard these days :blush:
    Thanks man!
    I'm not to worried, once the wires are inside the combs the complete cable becomes very stiff.
    You could literally hold a 1 meter long extension vertically :)
    So once they are in shape and position they won't go anywhere.
    First problem I would walk into would be the aluminum cases I often use :)
  2. Icelander
    Icelander Minimodder
    3 Mar 2015
    love those Clips....
  3. l3p
    l3p www.^.nl
    1 Nov 2010
    Summer vacation!
    And like every year .. modding! :)
    I've been looking for a proper solution to support the GPU's and Rads for a few weeks.
    Then I found this in a dusty corner at work.
    Nickel plated copper rails which are used for 12V halogen lamps.
    First had to brainstorm and draw a few hours about the loop and some other things
    And finally .. think I got it :)
    Made bends in the Rad supports.
    Sturdy stuff.
    And making mounts for it.
    The radiators are being pushed to the inside by itself because of how I mounted them.
    These supports will make the whole more sturdy.
    And starting on the loop.
    Lovely working with PETG, pipecutter and deburrer :)
    Here a little video about the Henco deburrer.
    18 months ago I saw an air-conditioning guy working with PVC/Alu/PVC pipe.
    I thought .. that should work with acrylic too, finally found the 12mm version a few months ago.
    And making 3 bends to save some extenders and rotaries.
    Bottom done according to my drawings :)
    Fitting the GPU supports.
    Now to drill some holes in the backplates.
    And make the holes in PCB's a little bigger :O
    From M3 to M4.
    Done!
    Next update more on the loop!
  4. storm-83
    storm-83 Minimodder
    7 Nov 2014
    looks like a modern piece of art - more than a pc!
    would have sh!t bricks drilling bigger holes in a pcb like that
  5. Cheapskate
    13 May 2007
    Technically, the rails can be called tubes since they are hollow. ;)
    Looking sharp, and heavy!
  6. l3p
    l3p www.^.nl
    1 Nov 2010
    Thanks man! I once did the same in a MARSII .. I did **** bricks back then :)
    At work we always use the word 'rail-system' for these kind of things. Already had some questions where to get it and had to google for '12V rail lamp' stuff to find it.
    But yes it's tube/pipe :)
    As in your very first comment in this thread.... you were also right :blush:
    Should've stayed with ITX and single small GPU ... but nothing was available at the moment.
    I did several tests and a single fitting can hold up to 10kg.
    However when you build a structure which seems very sturdy, you could throw it around, after a few days it will sag like a pudding lol.
    Off course you can make the structure so it won't be able to sag but you would need such an amount of Q-blocks and connections it wouldn't make sense anymore.
    Therefore this particular project .. will just go on to make it look nice.
    The loop/case thing .. soon ;)
  7. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Shame that you couldnt fulfill your brief,no shame in taking a diversion tho if it works out for the better.
    Maybe frame the rig with the loop instead rather than a loading structure?
  8. l3p
    l3p www.^.nl
    1 Nov 2010
    Most of my modding is like ... I'll see where it goes.
    At this moment I really like where it's going now, without a structure or frame... but who knows what will happen the coming weeks :)
  9. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    I like your "improv" modding. :) It's always interesting to see guys with creative minds coming up with solutions. Great stuff! :rock:
  10. Icelander
    3 Mar 2015
    totally Godlike
  11. l3p
    l3p www.^.nl
    1 Nov 2010
    This year 2 weeks on a nice camping place where my parents also are.
    I thought .. if I really want to relax .. why not take my hobby with me? :)
    Because the week started with bad weather (off course) I was able to leave the pc in my parents caravan.
    Great spot when it's raining outside ;)
    A day of shopping.
    Also finally some time to sort some things.
    And 4 days later finally some good weather! The one in the middle is my little spot :)
    This is relaxing! :D
    Waste after 3 days of working with the loop.
    And further on the backside.
    Had to take a few shots in the sun :)
    Decided to go home 2 days earlier so I could finish it with no people around me.
    Creating cable to feed the pumps and Corsair Link
    The last cables.
    Drilling and tapping the last hole.
    Finally filling!
    Loop 1 .. no leaks!
    Quite some foam with 2 pumps @ fullspeed.
    Decided to use anti cyclone fittings in the reservoirs.
    Loop 2 also leakfree!
    I should fill it up soon ... because this .. just looks weird :D
    Even first boot went well!
    Soon final pics :)
  12. saxovtsmike
    saxovtsmike Minimodder
    12 Aug 2008
    how many WTF & What is that did you get on the camping place
  13. bulldogjeff
    2 Mar 2010
    I just love how industrial this looks, kind of reminds me of an old factory with the cooling pipes running on the outside of the building. I love this style, not something you see very often. The cable management is brilliant with a full 4 sides being in view.. top modding. possibly my favorite build this year.
  14. l3p
    l3p www.^.nl
    1 Nov 2010
    Nearly everyone walking by stopped to ask what it was.
    I asked them what they thought it was.
    Things I heard: 'Steam Machine', 'Espresso Machine', 'Steampunk thing', 'Spaceship', 'Jukbox' etc.
    So much fun :D
    Well thanks a lot man, means a lot to me!
    I had no clue at the start where it was going and after 9 months of staring and building I was so happy to finally fill it :dremel:
  15. Attila
    Attila still thinking....
    22 Feb 2008
    As Jeff said, I also love the industrial, machine look. :thumb:
    Looking forward to final pics.
  16. l3p
    l3p www.^.nl
    1 Nov 2010
    Attila ... you sir have built my most favorite mods .. ever.
    I would build a 12 month mod just to get a comment like that from you :rock:
  17. Cheapskate
    13 May 2007
    Obviously no bears in the Netherlands... And we need a pic of you in the Disney hat!
    Looks awesome, except for the milk.:D
  18. l3p
    l3p www.^.nl
    1 Nov 2010
    Haha the last (brown) bear was seen in the Netherlands around 1100 AD :worried:
    I'm sorry about the hat, she won't let me near her holy frozen collection.
  19. l3p
    l3p www.^.nl
    1 Nov 2010
  20. Waynio
    Waynio Relaxing
    20 Aug 2009
    Turned out nice, congrats. :clap:
    Nice entertainment unit too. :D
