Modding Label-removing help
Discussion in 'Modding' started by robotguy9000, 6 Jun 2004.
  1. robotguy9000
    robotguy9000 What's a Dremel?
    3 Jun 2004
    How do you remove those fcking annoying labels on hard drives, etc? You can tear them off but they leave a paper/sticky residue behind... what product should i use to remove it? :wallbash:
  2. Hex L0ck
    Hex L0ck What's a Dremel?
    18 Apr 2004
    Ammonia based cleaners... nail polish remover, citrus stain remover, that sort of stuff.
  3. Andersen
    Andersen Brain for hire
    25 Nov 2002
    Isopropyl alcohol.
    Good for removing glue residue, thermal paste and fingerprints. :D
  4. robotguy9000
    3 Jun 2004
    ok.. i have alcohol
    yeah, i was using goof-off, that didnt work very well :wallbash:
  5. LucSkyywalker
    LucSkyywalker What's a Dremel?
    6 Jun 2004
    Goo Gone
    Found at any Wal-Mart, K-Mart, Mart-Mart!! lol :D
  6. robotguy9000
    3 Jun 2004
    uhh... i was using that but it didnt work very well... and it damages plastic :eeek:
  7. LucSkyywalker
    6 Jun 2004
    Really?
    Must of got a real booger of a sticker...i usually rip the sicker off take a small piece of sand paper...lightly scrape the paper, then use the goo gone on a sponge to remove the rest. If you're plastic is getting messed up try wetting the sponge. Trying to help! :D
  8. D B
    D B What's a Dremel?
    11 Apr 2004
    Just a side note , I didn't want to void the warr. on my WD 120Gb HD by removing the lable but it was going to be in the top of my case next to the window so I used that model airplane covering stuff that shrinks when heated ( Coverrite ? ) Got the chrome and covered the sticker and trimed the edge to the shape of a window in the HD , looks good ( black would make good window )
    DB
  9. Hwulex
    Hwulex What's a Dremel?
    1 Feb 2002
  10. robotguy9000
    3 Jun 2004
    :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop:
    SCHAWEEEEEEEETT!!!
    that is obviously the obvious answer, but where do you get it?
  11. 1st time modder
    1st time modder What's a Dremel?
    21 Dec 2003
    obviously not here in the US. :hehe:
    no but you could do a search for it on yahoo or google, for the american counter-part.
  12. robotguy9000
    3 Jun 2004
    hmm... i found out where to buy it in the UK... but strangely enuf, a yahoo shopping search reveals quite a few 3M products that im going to give a try... hmm wal-mart should have those...
    wal-mart is the ultimate modder's resource :dremel:
  13. jezmck
    jezmck Minimodder
    25 Sep 2003
    white-spirit / lighter-fluid will both do the trick...
  14. robotguy9000
    3 Jun 2004
    lighter fluid? :jawdrop: :jawdrop: :jawdrop:
    wouldnt that damge plastic though?
  15. fg0d
    fg0d Banned
    18 Jan 2004
    adhesive remover.. from odd job (US) or in some kmart
  16. robotguy9000
    3 Jun 2004
    okey dokey, im heading over to walmart AS WE SPEAK
  17. Blood
    Blood What's a Dremel?
    4 Jan 2004
    that little can of servisol **** is available ur local maplin electronics store:)
  18. jezmck
    jezmck Minimodder
    25 Sep 2003
    never had any problems myself - but i see you're at WalMart right now so let us know how it goes...
