Scratch Build – In Progress "Lady Liberty"
Discussion in 'Project Logs' started by MAG, 26 Feb 2010.
  1. MAG
    MAG like Rocklander? => Thx for vote
    13 Jul 2009
    Hi together,
    today I like to start with a small "in-between" project.
    The name of the project: [​IMG]"Lady Liberty"[​IMG].
    In the torch is a E14 bulb sockett. That will be unchanged.
    I've got a notion that she was hollow. If not I got a lot of things to do.
    The pics:
    My ideas for the back:
    - In the upper area a perforation for the circulation
    - The lower area (green) will be cut and mount with hinges out will be replaced with a plain Backplate.
    Maybe I mount some feet to rise the hole thing a little bit. Than I can make a input for the air. Of course with filter in front of it.
  2. Bullitdodger
    Bullitdodger If it ain't broke....Tweak it.
    9 Oct 2005
    Ugly lamp Cheesecake
  3. Cheapskate
    13 May 2007
    :lol: A Statue of Liberty lamp, with a European plug.
    Cheese does exist outside the US-Mexico borders.:hehe:
  4. MAG
    13 Jul 2009
    Do you know that the Statue is a "European Girl"? :hehe:
  5. FrooP
    FrooP can I eat this?
    24 Oct 2007
    everyone knows shes a frenchie :p
  6. benji2412
    benji2412 <insert message here>
    25 Apr 2009
    She sure is, had the pleasure of seeing the mini one in Paris. A gift to the people of the USA for winning their independance if memory serves me correctly?
  7. Cheapskate
    13 May 2007
    :lol: Yes. It's the fact that it looks like a child-sized souvenir that amused me.
  8. MAG
    13 Jul 2009
    Today I take a look under her skirt.
    First some moderate beats with a claw hammer...
    ... than regardless of the consequences.
    For the beginning is a rough handling ok.
    A picture from a Koloskopie ?
  9. vils
    vils What's a Dremel?
    4 Jun 2006
    Did you take that last pic with a endoscope? Yikes.
    Looks like you'll have som space issues but good luck.
  10. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    So that's what chicks look like on the inside. hmm pretty dark.
  11. MAG
    13 Jul 2009
    Snow again???
    I think it's clean enough
    This is a Rest from the Projekt "Rocklander". Now I have to look for the right place.
  12. MAG
    13 Jul 2009
    UPDATE!
    Today I got the PSUs. (25,5 x 6,5 x9 cm)
    Fore only 3,99€ I take two. Is always useful to have cheap spare parts.
    I want to use only one Powercord for the PC and the torch.
    Therefore...
    An old connector is exact what I need.
    After the drawing...
    ... and a view minutes with the DREMEL...
    ...it fits like a glove.
    Here the inner-view:
    At this point: Thanks DREMEL for your assistance.
  13. MAG
    13 Jul 2009
    And it goes on...
    To share the power I use this clamps
    Thin arrangement will be perfect.
    The flow:
    The switch will be mount on the back. For that I first mark the position...
    ... an drill the biggest possible hole. 13mm.
    After the drill I use a 90° countersink...
    ..and a Dremel with a 9904 Tungsten Carbide Cutter.
    I use the counterbore as an "optical guidance"
    Done :D
    UPDATE
    Next Step: "The cable channel"
    I think the pictures says enough.
    For a better visual appearance I use some self-adhesive felt.
    I also is some kind of protection for the cables.
  14. MAG
    13 Jul 2009
    The first try-on:
  15. Ink-Modding
    Ink-Modding ▀▀▀▀▀▀▀▀▀▀▀▀▀
    15 Mar 2010
    Hello.
    Very good start.
    Your cuts are very clean, nice
    __________________
    -                          INK-Modding.com                         -
  16. MAG
    13 Jul 2009
    The End or just a chance?
    Later more.
  17. Elledan
    Elledan What's a Dremel?
    4 Feb 2009
    You broke it :(
  18. MAG
    13 Jul 2009
    Just an accident. :wallbash:
    I think only to glue it will no be strong enough.
    Therefore I remove the bushing...
    ...and open up the channel a little.
    First with the Dremel...
    ...than with a 13mm drill.
    Why that? Its easy. I have here rest of a copper pipe that I will use as an reinforcement.
    First I cut the elbows...
    ...than I clean the edges.
    After a little bit of bending:
    The break in the upper arm with the pipe inside,
    the wrist...
    ...and the bottom of the torch.
    Tomorrow more.
  19. Elledan
    4 Feb 2009
    At least it's beginning to look even more like the real statue of liberty this way, aside from it having a steel (iron?) skeleton with copper skin :)
  20. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    Awesome! Fiberglass is awesome to work with. Itchy, but very forgiving.
