Scratch Build – In Progress "Lady Liberty"
Discussion in 'Project Logs' started by MAG, 26 Feb 2010.
  1. MAG
    MAG like Rocklander? => Thx for vote
    13 Jul 2009
    To fix the brake I use some fiberglass with polyester resin
    I let the pictures speak for themselves
    [​IMG].
    Later more.
  2. MAG
    13 Jul 2009
    This is the Shoulder-Break
    I also filled it with resin and glue the fragment on top.
    Now it is time to fill the gap..
    ... and use the surplus resin to hold the next part in place.
    The same procedure on the top
    While the arm need some time to dry, I take care of the crown.
    First I glue it with Loctite and than I cut a slot for an extra reinforcement.
    To old screws will do a good job
    Of course without the heads
    Here is the first glued with resin in place
    That will be strong enough
    The Arm is dry. Now I can start with the next steps.
    The Pipe is still to long.
    Its nothing special with a simple saw.
    The surface after the first grinding.
  3. MAG
    13 Jul 2009
    I fix the second needle like the first one.
    First the Glue and a slot for the reinforcement..
    ..tha a bolt with some resin
    The arm are pretty strong. It only looks like a bad skin disease .
    The third needle will be more work.
    I cant find the part and need to rebuild it.
    Therefore I use a small drill...
    ... to mount a self-tapping screw
    Again without the head.
    To rebuild the needle I use some resin and fiberglas strings.
    Later more...
  4. MAG
    13 Jul 2009
    After another resin I start with the grinder.
    I hope I can go on with the Hardware. This repair... sucks.
  5. nlancaster
    nlancaster Minimodder
    21 Dec 2009
    Great fiberglass work. Good idea with the screws to reinforce the spikes.
    Should use the copper tube to have a real flame instead the plastic flame.
  6. Alekoy
    Alekoy Ostekake!
    28 Dec 2003
    Well, I knew she was from france, but now I also know that she IS french, at least judging from the hairy armpit... :jawdrop:
    Nice work thou
    stonedsurd likes this.
  7. oliverw92
    oliverw92 What's a Dremel?
    15 May 2009
    Shes bleedin man!
  8. nlancaster
    21 Dec 2009
  9. MAG
    13 Jul 2009
    Nothing new.
    Therefore only some pics from the actual status.
  10. MAG
    13 Jul 2009
    Today only a small Update:
    That was the old E14 bulb socket.
    Now I need to replaced it. Maybe I use some LEDs.
