Windows Lagging in windows vista... wtf, need help!
Discussion in 'Software' started by Crazyglue, 15 Mar 2007.
  1. Crazyglue
    Crazyglue What's a Dremel?
    27 Nov 2005
    ok i have windows vista ultimate. and every like 1min-1 1/2 min, i get this strange lag that slows down everything, sound, video, mouse movement, keyboard typing, everything! this is really annoying, i figured i should update, and i did, and then i got the newest video drivers, and still nothing... need help, this is really annoying and cant afford to reinstall atm...
    thx
    Crazyglue
  2. kenco_uk
    28 Nov 2003
    Have a look in Task Manager and see what process is causing the CPU usage to spike. Or try a search-everywhere Windows Defender and Antivirus scan.
  3. Crazyglue
    27 Nov 2005
    hmmm, while i have the task manager up, it doesnt seem to lag, at all.
    quick question, is there a guide to disabling windows services for vista? link would be great :thumb:
  4. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Can you open the resource manager and look there?
    I use this guide myself, but I don't think it's a misbehaving service (unless you're running 3rd party ones like AV or something, those can cause memory leaks.
  5. severedhead
    severedhead What's a Dremel?
    19 Dec 2002
    Remove any uneccesary hardware? I had a similar problem with XP a few years back which turned out to be a dodgy firewire card.
  6. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    I don't know if it specifically addresses problem such as you're having... but you might find this Tweaking Windows Vista article useful anyway?
  7. Crazyglue
    27 Nov 2005
    removed all unnecessary hardware (was only a stupid front firewire connector, need my dual gpus) and no change :-(
    went through the vista tweak guide with no results, but less ram usage :p
    scanned my entire harddrive with ad-aware, avg, symantec, and no results
    watched my task manager as it was happening, System idle process was still the most cpu usage..
    any other suggestions? plz help!
  8. severedhead
    19 Dec 2002
    Have a check in the Reliablility and Performance monitor. See if anything else is spiking, like the HDD or RAM usage.
  9. Crazyglue
    27 Nov 2005
    ok, i found out what the problem was
    on my abit aw9d-max, the little pci slot sound card thingy was plugged in, and i had the front audio plugged into that. when i unplugged it everythign worked great! lol
    finally i can game in peace :cooldude:
  10. Crazyglue
    27 Nov 2005
    ok, the problem started again, only on my mini/lan PC... i have almost nothing plugged in... please help!!!! tried everything above again, and with no luck :-(
  11. kenco_uk
    28 Nov 2003
    I found last night for some reason Steam was causing massive spikes in usage, so set the priority of it in task manager to lowest, which seemed to do the trick.
  12. Crazyglue
    27 Nov 2005
    ok thanks, im gonna try that and see what happens
