Modding Laing DDC1-T
Discussion in 'Modding' started by kelvinb, 14 Oct 2011.
  1. kelvinb
    kelvinb BF3 Username - D0rmarth
    20 Sep 2011
    Hi all,
    I was wondering if anyone could point me in the right direction as I have a Laing DDC1-T pump and I am looking for a Reservoir which this can be housed into rather than have it as seperates.
    My preference is to have a bay mounted reservoir any ideas or anyone selling this ??
    Many thanks :D
  2. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
  3. kelvinb
    20 Sep 2011
    I was looking at those but as Im only cooling the CPU i wasnt sure that it was an over kill I think they do a single pump one though
  4. GuilleAcoustic
    26 Nov 2010
  5. kelvinb
    20 Sep 2011
    been thinking about that but to be honest I have limitations due to the size of the case I am using, currently I have NZXT gamma case but im thinking that it might be worth buying bigger as I will always be limited to what I can do in my current case
  6. GuilleAcoustic
    26 Nov 2010
    That's what planing and research are made for. I know this feeling, always have hard time finding the appropriate stuff regarding my constraints.
    I hope you'll find the good res. If I find something that might interest you I'll let you know.
  7. Kernel
    Kernel Likes cheese
    29 Sep 2003
  8. GuilleAcoustic
    26 Nov 2010
    They can be bay mounted but takes 2x 5.25" baies.
  9. davebodger
    davebodger My Dremel's bigger than your Dremel
    7 May 2009
  10. GuilleAcoustic
    26 Nov 2010
    I suggested that in the first reply, but he's looking for a single bay solution ... except the koolance, I do not know and single bay mounted res combo
