Modding Lamptron FC-2 Fan Controller Aesthetic Mod
Discussion in 'Modding' started by IKIKUINTHENUTZ, 15 Jun 2009.
  1. IKIKUINTHENUTZ
    IKIKUINTHENUTZ What's a Dremel?
    15 Jun 2009
    Hey everyone! First post here ever on a UK forum :dremel:
    Lamptron FC-2 fan controller mod
    MFG Product Link
    I introduce my modification, my LED switch out and how to fix the not fully lid LED lights on the sides of the unit.
    For those of you who don't know, this fan controller has an aesthetic problem of having the LEDs not show up in the corners. Below here is a Image I borrowed from overclock3d.com
    As you can see, the unit uses bright blue LEDs and doesn't fully illuminate the unit at the edges.
    When I bought my black colored FC-2 from performance-pcs
    http://www.performance-pcs.com/cata...t_info&manufacturers_id=158&products_id=24896
    I was thinking that my LEDs were too bright and I wasn't too fond of blue and so I decided to switch it out.
    My original idea when I started with this project was to switch out the blue LEDs in favor for white LEDs, however during the process I learned some important facts and then I decided to fix the non side illumination issue along with switching out the LEDs.
    First I unscrewed the whole unit apart
    After doing that I decided to inspect the unit and I noticed this
    If Lamptron indeed put a led on the sides, then why doesn't it show? I quickly plugged it in and I decided to look at the back of the unit while I was turning the knobs, indeed it lit up perfectly fine but why doesn't it show? The image below practically shows why, a piece of metal blocks the way.
    Another shot of the unit with the metal off
    While searching the internet for the LEDs, it was pita finding them in size of 2X5X6mm flat rectangular white leds so I decided to get these white 2X5X7mm from ebay
    link
    After I received them, it took 6 hours total to solder the old ones out and put in the new ones with just a soldering iron. My end result was worth it because it came out to be not too bright or blue.
    Perfect
    Now for the piece of metal, I went to my local hardware store and bought a brand new Dremel and a miniature hobby table so I can cut the little darn thing. Luckily with purchase of a new Dremel, they give you a sample cutting disk and grinding disk inside the box. I didn't have to spend extra money for more tools.
    After cutting the edges off and grinding 1mm all around the openings to accommodate the new bigger LEDs, this was my end result. It's not perfect but it's well hidden anyways when it's put back together. This took me around 15 minutes to do.
    Now the finished product images.
    A few days later
    I was talking to nd4spdbh2 of Ocforums.com and he had given me an idea of how much light was bleeding out on to the back of the unit which was shown in my image. We talked about how to address it and then came up the idea of aluminum foil behind each led.
    Now ill be honest, working with small bits of aluminum and then gluing it on a slippery surface in the smallest work space available with 2 needles as tool is worth a lot of headaches but in the end, it worked out fine in the end.
    This resulted what I wanted, stronger front led lighting but what I didn't expect was the fact that it was too much, it was too damn bright just like Sunbeam Controllers! Ouch!
    After consulting with nd4spdbh2 again and seeing forums posts, I noticed people complained about how the lighting wasn't all around in a circle. The idea of diffusing the light came apparent.
    The installation is probably the most easiest mod I have done to this unit. All you need is some type of paper that still let light through, some glue, and a razor. In this case I used parchment silicone paper that is used in baking.
    Unscrew the face plate and slap the paper on with some glue
    Then use a razor and cut holes where appropriate for the knobs and screws.
    Then put everything back together and huzzah! Finished!
    Night time shot
    Guest-23315 likes this.
  2. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    That looks very nice. Good job with listening to your feedback too.
  3. Guest-23315
    Guest-23315 Guest
    Wow, that paper mod its rather neat! :thumb:
    +/rep for that
  4. IKIKUINTHENUTZ
    15 Jun 2009
    one final (hopefully) mod
    Acetone + Q-tip
    Finished!
  5. Krikkit
    21 Jan 2003
    Very nice indeed, always good to see a bit of understated modding. :D
  6. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    Just my style, keep it simple and sleek
