Lamptron FC5 V3 The best just got better
Discussion in 'Lamptron' started by Luciel, 26 Jul 2013.
  1. Luciel
    Luciel Needs more rust
    31 May 2011
    The Lamptron FC5V3 fan controller is not only a revision of the FC5V2 but it is a real step forward in the evolution of these kind of products. This fan controller is positioned to become the new refference point in the cooling domain. In fact, the Lamptron FC5V3 has 6 channels and can handle up to 30 W per channel. The new wide LCD display shows all the information (RPM, temperature and voltage) for every channel. Moreover, the display allows a new level of customization providing 16 different colors for the illumination of the LCD display. The FC5V3 integrates all the commands directly on the front of the fan controller for an enhanced and quicker access to all the functions. Moreover, the FC5V3 provides an initial 12 V (startboost) on all the channels in order to make the fans work even if set at the minimum working voltage.
    Now avaliable at Xoxide:
    http://www.xoxide.com/lamptron-fan-controller-fc5-v3.html
    And Oliospec:
    http://www.oliospec.com/item_detail/itemCode,LAMP-FC5-V3/
    Want more info on the FC5-V3? Check out the product page over at our website:
    http://www.lamptron.com/product/controllers/fc5-v3/
