Lamptron Vandal Resistant Illuminated Switch
Discussion in 'Industry News' started by Guest-16, 28 Mar 2008.
  1. Guest-16
    Guest-16 Guest
    I thought this might be of interest to some modders.
  2. mr00Awesome
    mr00Awesome YEAH SWEET LEMONADE
    23 Jan 2008
    looks quite familiar
  3. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Only thing they need is the Bulgin name on the packaging.
  4. Sparrowhawk
    Sparrowhawk Wetsander
    14 Feb 2004
    Huh. Any idea how these compare to the Bulgins?
  5. E.E.L. Ambiense
    26 Jul 2007
    Sure! Generally how knockoffs compare to originals! :hehe: Seriously, I'm sure they work fine.
  6. shadrag
    shadrag What's a Dremel?
    28 Mar 2008
    I've tried one of these (more specifically the 16mm one, smaller than the bulgin). There are actually quite a few differences.
    The lamptron uses colored plastic for the led, while the bulgin uses clear.
    The lamptron is smoother, while the bulgin is more angular.
    The lamptron button has more travel and a click at the end, while the bulgin travel is short with more of a thud at the end.
    In person the lamptrons look a bit different than bulgins, not bad tho, I think I actually prefer the lamptron look slightly. However, I think the lamptron button travel is too long.
    My main problem with the lamptron, however, is that attempting to solder wires to it melted the innards until it no longer worked and I'm actually pretty decent at soldering.
  7. MaximumShow
    MaximumShow Minimodder
    20 Jan 2003
    Any links as to where they can be purchased? I might be interested if they are a bit less expensive than the Bulgins, and can be found in Canada.
  8. shadrag
    28 Mar 2008
    I got it from performance-pcs by acccident. They are slightly cheaper than bulgins can be had, but I won't be getting one ever again.
  9. TiTON
    TiTON IRONMODS
    23 Mar 2004
    the price point is cheaper then bulgin.. seems to run about $15 at performance PCs.. i typically see bulgin for around $20. I might ahve to give them a try.
    Ton
  10. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    :confused: Why solder? Don't they have screw terminals?
  11. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Screw (though not available in such from Performance-PCs AFAICS) or 2.8mm tag, but 2.8mm is not the most common of push-on connector sizes...
  12. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    Got me a black one with orange led ring :)
  13. Spacecowboy92
    Spacecowboy92 Gettin' Lazy
    10 Apr 2006
    Shouldn't that be ROHS Compliant rather than Complaint?
