Scratch Build – In Progress LAN-Party Laptop 2015
Discussion in 'Project Logs' started by Coolone, 28 Dec 2015.
  1. Coolone
    Coolone Minimodder
    22 May 2009
    Worklog - Part 01
    By Coolone
    a. Name of mod:
    LAN-Party Laptop 2015 - Portable High-end Gaming Case Mod
    b. Description of my case mod:
    Idea
    For my “LAN-Party Laptop 2015 - Portable High-end Gaming Case Mod” I will use an Aluminum Suitcase and cut out some holes so it is possible
    to mount the hardware inside the case and making it possible to ventilate the case as well. I will use some Cooler Master Case Fans to keep
    it "COOL" and I will maybe also use some Cooler Master Ultra Aurora CCFL Lights to let it look "COOL".
    Aluminium Suitcase - WISENT TOOLBOX ORGANIZER
    The whole idea is to make a powerful nice looking case mod which is possible to take with me to LAN-parties. The most important thing with
    this case mod is to get an mobile powerful gaming setup and to ensure all the hardware while traveling.
    c. HOMEPAGE:
    Homepage for my case mod.
    http://www.lanpartypathfinder.com/casemodding/lanpartylaptop2015/ ( None so far )
    d. Introducing Pictures:
    Some picture of my mod case mod.
    e. Cooler Master Hardware setup:
    Some picture of the Cooler Master hardware I have used for my case mod.
    Cooler Master - Fan 80mm
    2 pieces Case Fan 80mm
    Cooler Master LED Silent Fan Blue TLF-S82-EB
    http://www.coolermaster.com/
    Cooler Master - Fan 120mm & 140mm
    2 pieces Case Fan 120mm
    Cooler Master 120mm LED Fan On/Off Blue 200025090 - GP
    1 pieces Case Fan 140mm
    Cooler Master 140mm LED Fan On/Off Blue 200018380 - GP
    Cooler Master 140mm LED Fan On/Off Red 200016700 - GP
    Cooler Master Northbridge Chipset Cooler
    1 piece Cooler Master Blue Ice Pro RR-NCW-L4E1-GP
    Cooler Master - Thermal Compound
    1 piece Thermal Compound
    Cooler Master NanoFusion Supreme
    f. Hardware:
    Description of the hardware I have use for my case mod.
  2. Coolone
    Coolone Minimodder
    22 May 2009
  3. Coolone
    Coolone Minimodder
    22 May 2009
    Worklog - Part 03
    By Coolone
    04 Graphics Card
    ATI CGA-928PTVD Radeon 9200SE 128Mb DVI TVout PCI 3.0
    http://www.amd.com/en-gb/products/graphics/desktop/
    05 Hard Drive
    WD Green WD60EZRX SATA 6 Gb/s 3.5 Inch IntelliPower 6 TB 64 MB
    http://www.wdc.com/en/
    06 SSD
    None
    07 Power Supply
    Some picrutes of the Power Supply I have use for my Case Mod.
    08 Cooling
    To take hot air out of my Case Mod there is used the following fans.
    Cooler Master 80mm Fan LED Silent Blue TLF-S82-EB
    DELTA DC BRUSHLESS BFB0712H Fan MILL
    ( Click on picture for large picture )
    For cooling the Northbridge Chipset there is used the Cooler Master Blue Ice Pro RR-NCW-L4E1-GP Chipset Cooler.
  4. Coolone
    Coolone Minimodder
    22 May 2009
    Worklog - Part 04
    By Coolone
    For cooling the hard drives there is used an OLD Cooler Master 70 mm PCI Slot Fan.
    For Cooling the CPU there is used an Cooler Master 120mm Blue On/Off LED Fan.
  5. Coolone
    Coolone Minimodder
    22 May 2009
    Worklog - Part 05
    By Coolone
    f. Hardware:
    09 CPU Cooling
    For cooling the CPU I decided to use an be quiet! SHADOW ROCK TOPFLOW CPU Air Cooler together with an Cooler Master 120mm Blue On/Off LED Fan
    to let it look "COOL" as well.
    be quiet! SHADOW ROCK TOPFLOW CPU Air Cooler - Supporting the very old Socket 939
  6. Coolone
    Coolone Minimodder
    22 May 2009
    Worklog - Part 06
    By Coolone
    g. Hardware setup:
    Pictures of the hardware setup for the case mod.
    h. Build Phase:
    Pictures of the Build Phase of my case mod.
    Build Phase 01: Buying Parts from Cooler Master Europe Part Store
    Build Phase 02: Cutting out holes for ventilation / mounting parts and painting edges silver.
  7. Coolone
    Coolone Minimodder
    22 May 2009
    Worklog - Part 07
    By Coolone
    i. Case Mod Finished Outside:
    Pictures of the outside of the finished case mod.
    j. Case Mod Finished Inside:
    Pictures of the inside of the finished case mod.
    k. Case Mod Finished Running:
    Pictures of the running finished case mod.
  8. Coolone
    Coolone Minimodder
    22 May 2009
    Worklog - Part 08
    By Coolone
    l. Video of the Finished Case Mod:
    Video: Case Mod Finished Running
    LAN-Party Laptop 2015 - MVI 0959
    https://www.youtube.com/watch?v=Z-vteTaDRhQ
    m. Thanks for taking a look at my case modding project.
  9. saxovtsmike
    saxovtsmike Minimodder
    12 Aug 2008
    nice work, sadly the hardware wasn´t even near high end back in 2008 even earlier.
    An actual Notebook with internal non discrete GPU could be easier to transport and be more powerful.
  10. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    Why are you using that font colour against a white background? It's really difficult and eye straining to read.
  11. Coolone
    Coolone Minimodder
    22 May 2009
    Hi saxovtsmike & HandMadeAndroid
    Thanks for coming back to my Case Mod!
    Yes, you are right the silver color is not good in the forum. I have changed it now to cyan, the reason was that the Aluminium Suitcase is silver so i thought that I would use the same color in the forum.
