LAN-Party RGB Laptop 2018
Discussion in 'Project Logs' started by Coolone, 30 Nov 2018.
  1. Coolone
    Coolone Member
    22 May 2009
    Worklog - Part 01
    By Coolone
    a. Name of mod:
    "LAN-Party RGB Laptop 2018"
    b. Description of my case mod:
    Idea
    For my "LAN-Party RGB Laptop 2018" Case Mod I will use an Black Aluminum Suitcase and some nice aluminums rods in "mirror like" finish for the Frame Structure combined with some nice wood.
    I will use some nice RGB components for my Case Mod.
    I will build it up in an modular way inspired by the modular way the Cooler Master MasterCase Series is made. If I build it up in an modular way the Case Mod will be something like an test bench.
    Module 1: The Aluminium Suitcase
    Module 2: The Frame Structure Design with nice wood
    Module 1 & Module 2
    Module 1 + Module 2: Module 2 fits into Module 1 = For safe transportation
    Module 1 + Module 2: Module 2 fits on top of Module 1 = Test Bench = Portable High-end Gaming Case Mod
    c. Introducing Pictures:
    Some introducing pictures of my case modding project.
    TOOLMATE DT-932078 - 460 x 335 x 150 mm
    http://www.silvan.dk/
    Module 2: The Frame Structure Design with Motherboard Tray
    Safe transportation: Module 2 fits into Module 1
    Test Bench: Module 2 fits on top of Module 1
    d. Test Bench:
    Some information and pictures about Test Bench.
    In hardware terms I think Test Bench is most of all used by Overclockers.
    "Test Bench" - Wikipedia
    https://en.wikipedia.org/wiki/Test_bench
    A test bench or testing workbench is an (often virtual) environment used to verify the correctness or soundness of a design or model, for example, that of a software product.
    The term has its roots in the testing of electronic devices, where an engineer would sit at a lab bench with tools for measurement and manipulation, such as oscilloscopes, multimeters, soldering irons, wire cutters, and so on, and manually verify the correctness of the device under test (DUT).
    In the context of software or firmware or hardware engineering, a test bench refers to an environment in which the product under development is tested with the aid of software and hardware tools. The suite of testing tools is often designed specifically for the product under test. The software may need to be modified slightly in some cases to work with the test bench but careful coding can ensure that the changes can be undone easily and without introducing bugs.
    Cooler Master Test Bench v1.0
    https://eu.coolermaster.com/en/case/case-by-modularity/test-bench-v1/
    ( Click on picture for large picture )
    Cooler Master Test Bench v1.0 - Product Sheet
    Cooler Master LAB Test Bench v1.0 Review - Guru3Dcom
    https://www.guru3d.com/articles-pages/cooler-master-lab-test-bench-v1-review,1.html
  2. Coolone
    Coolone Member
    22 May 2009
    Worklog - Part 02
    By Coolone
    Sorry but!
    A new LAN-Party case mod is under development.
    The upcomming LAN-Party case mod I will call "LAN-Party RGB Case Mod 2020 ( Wood Edition )".
    For the new Case Mod I will use nice wood between the "mirror like" finish aluminums rods in the Frame Structure and I will use some nice RGB components for my Case Mod as well.
    BR
    Coolone
  3. Coolone
    Coolone Member
    22 May 2009
    Worklog - Part 03
    By Coolone
    Sorry but!
    BR
    Coolone
  4. Coolone
    Coolone Member
    22 May 2009
    Worklog - Part 04
    By Coolone
    Sorry but!
    BR
    Coolone
  5. Coolone
    Coolone Member
    22 May 2009
    Worklog - Part 05
    By Coolone
    Sorry but!
    BR
    Coolone
  6. Coolone
    Coolone Member
    22 May 2009
    Worklog - Part 06
    By Coolone
    Sorry but!
    BR
    Coolone
  7. Coolone
    Coolone Member
    22 May 2009
    Worklog - Part 07
    By Coolone
    Sorry but!
    BR
    Coolone
  8. Coolone
    Coolone Member
    22 May 2009
    Worklog - Part 08
    By Coolone
    Sorry but!
    BR
    Coolone
  9. Coolone
    Coolone Member
    22 May 2009
    Worklog - Part 10
    By Coolone
    Sorry but!
    BR
    Coolone
  10. Coolone
    Coolone Member
    22 May 2009
    Worklog - Part 11
    By Coolone
    Sorry but!
    BR
    Coolone
  11. Coolone
    Coolone Member
    22 May 2009
    Worklog - Part 13
    By Coolone
    Sorry but!
    BR
    Coolone
  12. Defyant Mods
    Defyant Mods Well-Known Member
    14 Sep 2004
    Wow did i just look @ 13 pics of a psu...?
    I'snt this case mod finished? im sure i see it at a lan.
    Looking good so far.
  13. Cheapskate
    13 May 2007
    Posting like this isn't very Alzheimer's friendly.
    Defyant Mods likes this.
  14. Coolone
    Coolone Member
    22 May 2009
