lan-pc with no name (10/03/2004) Aerogate II painted red
Discussion in 'Project Logs' started by white modder, 18 Feb 2004.
  1. white modder
    white modder What's a Dremel?
    19 Sep 2003
    1/this is my second real mod. so dont be to critic
    2/I dont have much time so dont expect pics every day
    3/my english isnt so good so... ... ...
    4/still searching for a name pls post in your reply's
    this pc is made for going to a lan so I didnt put expensive thins in it. my acryl is delivered somewhere next week (I hope) so I didnt made the window yet.
    went to the elec shop and got my first partie of parts to use
    first I putted a cold cathode in it with an inverter for an optionel second cold cathode
    use some crimp to make it nice and safe
    (didnt solder the damn things because I left my solderstation at a friends home)
    and???
    nice cablemess
    nightpics:
    (mom called me on last pic so it got a spooky effect )
    o yeah dont mind those crappy cut out pins on the fan blowouts I have to get it "clean" friday
    so what do you think???
    :confused:
    [edit] need some resizing will work tonight on it[edit]
  2. white modder
    19 Sep 2003
    how do you make an airfilter for dust (to use on the back off the pc before the fans
  3. jezmck
    jezmck Minimodder
    25 Sep 2003
    looks good, will need some cable tidying, but you're goin got that anyway.
    would recommend you put some fans on the front to pull air in, change those at the back to exhaust. (filters on the front fans.) filters can be made using aquarium filters, or using tights (stockings)) stretched over a frame.
  4. Morphious
    Morphious What's a Dremel?
    19 Jan 2004
    sweet, same case as me. :p
  5. 3N1GM4
    3N1GM4 What's a Dremel?
    23 Jun 2003
    i hope that isnt a dell pc... ooo please dont let it be a dell pc...
    lookin good, hope the lan goes well....
    wish i had money to build a new comp for A lan im gunna go to :(
  6. white modder
    19 Sep 2003
    euh a dell no, it is a self made system by me
    and it are just some old parts put in a standard case of Aopen
    amd 2200+, radeon 9200, 256 ddr ram pc 2700, that kind of parts
    and MX-500 +logitech elite keyboard
  7. 3N1GM4
    23 Jun 2003
    ok good, the third pic kinda makes it look like a dell... keept it up man
  8. curme
    curme Minimodder
    12 Sep 2002
    Looking good. Why not name it Bruce? :hehe: Bruise? :worried: Black and blue... aw forget it! :grr:
  9. Skaal-tel
    Skaal-tel What's a Dremel?
    12 Jan 2004
    Nation lan-poon?
    lan-basted?
    lan attack?
    network shmetwork? ok lol, not really serious with that one.
    heheheh. Maybe make the pictures smaller? 320x240 is fine for forum posts.
  10. white modder
    19 Sep 2003
    like I said before I havent much time but today I worked
    two days ago I sanded one side panel and used my dremel (just bought) :dremel: for a window
    today I painted the sidepanel (just one sidepanel to see if the color is good give your opinion), painted the bezel of my CD-writer and started sanding the grey area of my frontpanel and I'm working at a bay bus (pics in a few days)
    sry for my bad english
    so here they are the (resized!!!!) pics
    I know need some cabletidying (but I leave it untill I finished my baybus)
    so what do you think??? :confused:
  11. SJH
    SJH Minimodder
    24 Dec 2003
    J'adore le couleur. Rouge, c'est le meilleur couleur qui existe :) Et la fenêtre est bien coupé. Tu l'as coupé toi-même?
    Où en Belgique es-tu? (Je suis pas Français mais je (pense que je) le parle bien ;))
    Je regrette que mon Français ne soit pas parfait!
    -Sam
  12. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    good jobb with the project... nice job with the dremel and the window. Keep up the good work :dremel: :D
  13. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    looks good so far mate :p
  14. white modder
    19 Sep 2003
    ton francais est bien, trés bien
    dommage mais ma langue maternelle est neerlandais
    j'habite en aarschot-->vlaams brabant
  15. Oracle
    Oracle What's a Dremel?
    7 Feb 2004
    this is for any one who dose not speak french
    I adore the color. Red, it is best the color which exists And it
    window is well cut. You cut it yourself?
    Where in Belgium you are? (I am not French but I (that I think) speak
    it well)
    I consider it regrettable that my French is not perfect!
    - Sam
  16. white modder
    19 Sep 2003
    yes I did the cutting myself
    oui
  17. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Nice case, I saw it in a shop yesterday, and I'm pretty satisfied about the design. What I didn't get to check in the shop though: is it solid?
    I like the red color. Looks pretty cool I think. Will you keep the front black/silver, or will that be painted too?
  18. white modder
    19 Sep 2003
    yes it is a very solid case (to solid, to make those blowhole at the back ik spend 10 minutes). pretty cheap
    and the front is grey/black I'm planning to remove the grey and paint it red to
  19. white modder
    19 Sep 2003
    worked on this pc today
    this is what I did, I sanded and painted one of the panels.
    and use some polyfilla (you know what I mean) so I can sand it tomorrow
    <hr>
    <hr>
    more pics comming
  20. ReFredzRate
    2 Sep 2002
    Ahhhh... polyfilla!! :thumb: That's some good stuff. I used to use it for modding my moped :) Never went wrong, excellent stuff...
