Notebooks Laptop Advice
Discussion in 'Hardware' started by MrP, 11 Jan 2012.
  1. MrP
    MrP seeking inspiration
    5 Jul 2007
    Am thinking (again) about buying myself a new laptop.
    i'd like something with 4-5 hours battery life and a bit of gaming ability (bit of WOW, trackmania, maybe something else), 15" preferably
    as laptops now seem to have progressed i'm a bit stumped.
    i was looking at an acer 5750 with the nvidia 540m GPU, but to be honest, i dont know how much better that is than the standard 2nd gen core i3/i5 gpu, or AMD's llano GPU's.
    absoloute CPU performance isnt really that important, i'd image the hardest thing it would do it some youtube or iplayer HD content, maybe some 1080p mkv's
    budget is under £500
    lemme know what you think, and if the nvidia 540 GPU is worth it
    thanks
  2. derpooch
    derpooch What's a Dremel?
    11 Oct 2009
    My laptop has one in; it isn't a great GPU but still runs trackmania fine, I also play a bit of left for dead 2 on it. (I have the i7 version of the 5750). I seem to recall Llano's GPU being about on par/just behind the 540M when I was reading up on it. ( I will try to give a better answer when I am finished work)
  3. asye288
    asye288 What's a Dremel?
    3 Jan 2012
    If you perfer the Acer brand, I do recommend Acer TimelineX 8472T. It is an intel core i5 cpu, 600gb hdd, 4gb ram and 14" led backlit monitor. Battery life is about 7-8 hours depending on usage. I got one myself and I'm happy with it. I paid $700 a year ago, I believe the price has come down a bid.
