laptop cd-rw and hard drives
Discussion in 'Hardware' started by mookie, 7 Jul 2002.
  1. mookie
    mookie very nawty<br><img src="http://mookie.org/i/avatar
    30 Jun 2002
    first off i was wondering if you can buy laptop cd-rws and if so where, i was also wondering where you can buy laptop hard drives. and where do you get adapters for them, thanks
  2. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    havent seen laptop cdrws sold sepereatly, and if they were i would think they would be dreadfully expensive...
    laptop hdds can be bought pretty much anywhere, just look for 2.5" hdds not 3.5", and quite a few places also sell the adaptore...ie dabs, komplett and whatnot...these are uk places, wouldnt know for us...:idea:
  3. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    I picked up the Toshiba SD-R2002 its a cdrw/dvd combo laptop drive pic (i forgot how much it was, but it was pricey) and you can find adapters here and here good luck..
  4. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    when you are looking... I have found that it helps if you use "slimdrive" when you are searching... just a tip. Of course, that is for CD/DVD drives, doesn't really apply for hard drives.
