Modding laptop drive...
Discussion in 'Modding' started by Chobbler, 13 Jul 2004.
  1. Chobbler
    Chobbler Running with a Spoon
    17 Oct 2003
    well i have a laptop drive for my little epia pc thingy (coming to a project log near you soon) and i can't figure out how to mount it!!! it has no screw holes or anything so its making it difficult to place.
    anyone got suggestions on how to mount it?? :eek:
  2. SJH
    SJH Minimodder
    24 Dec 2003
    Get some heavy duty velcro, that ought to hold it ;)
  3. Chobbler
    17 Oct 2003
    simple and possibly effective...but i need something a little more eligant...it won't look very good in my plexi box if you see a huge chunk of velcro sitting there!!
    thanks though
    Any other ideas? :eyebrow:
  4. stoned penguin
    stoned penguin What's a Dremel?
    23 Mar 2004
    how about a plexi case over the hard drive which you then epoxy it to the case?
    :thumb:
  5. Chobbler
    17 Oct 2003
    *nudge* sorry....its optical drive...DVD ROM....i have the hard drive mounted....good idea though. Need something less permanent..
  6. stoned penguin
    23 Mar 2004
    you can always screw the casing into the plexi case instead of epoxying it
  7. Chobbler
    17 Oct 2003
    i would have screwed it in if it had screw holes...hence me asking how to attach it....unless i missed something there..
  8. FILTHY1337
    FILTHY1337 Senior Overclocker
    4 Jan 2004
    paint on side of a peice of acrilic, cut to the size and shape of the drive (yourchoice of color)...epoxy the clear side to the case and put velcro on the painted side so it will cover ugly stickers and mount it...hows that sound. may i ask were u got your ide converter?
  9. Chobbler
    17 Oct 2003
    These two places i think do them.
    http://www.ultim8pc.co.uk/
    http://linitx.com
    The guy i bought the Drive off (from the forum) supplied the converter with it.
    The thing about the case is you can see all around it and the drive should be suspended so you can see right around it...bar the things holding it...i'm just baffled as to how to connect it all!!
    your idea sounds good but a little confusing..
  10. FILTHY1337
    4 Jan 2004
    well let me calrify(spelling) basically make a box for it w/o a bottom or front paint the inside of the box a color (it will be miror finished on the other side) epoxy the top of the box to the case and velcro the drive inside of the new case. is that any better i can break out my 1337 paint skills if nessary :hehe:
    thx for the linki :thumb: just bought my slim combo drive of e-bay for $50 :D
  11. Chobbler
    17 Oct 2003
    i got you now. I don't think that will work the way i have made the case. its fairly compact...not tiny but compact....i am tempted to make a couple of brackets that just pop out from the front hole and hold the drive. your idea is great but because of the space i have used wouldn't work very well.
    good thing is i have about 3m of plexi....MUHAHAAHAHA £17 can't complain... :p
  12. stoned penguin
    23 Mar 2004
    yea i meant that you would make a plexi casing for the drive and instead of epoxying the plexi casing to the case you could screw the plexi casing into the case
    :thumb:
